Old 02-12-2012, 03:44 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: Manual gearbox Stall.
Originally Posted by Dessertrunner View Post
Stalling is back, I need to get my head around it and come back to everyone later.
Tony
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 02-12-2012, 08:43 PM
Dessertrunner's Avatar
Its just part of the evulation of finding the soluation. I need to run some tests tonight but it appears the adjuster on the throttle butterfly is not reliable enough to stay on the adjustment set. If this proves correct I need to make the change on the Idle valve.
This methord would be more work but would be better overall.
Tony
Old 02-17-2012, 02:28 AM
Apart from one day when the stall returned and I made a adjustment to the throttle body butterflys the car has been running well and not stalling. What I want to do is make the change I mentioned below, over all the current changes are and improvement.
Tony
Old 02-21-2012, 02:42 PM
About a week ago is the last time the car stalled, I adjusted the throttle body and the problem has gone away. It may be a matter of getting the right balance between the base line air throught the throttle body.
I will keep you posted as I learn more.
Tony
Old 05-16-2012, 08:12 PM
Okay I have been driving the car around with this mod for the last couple of months and I can say that the stall issue is gone. Given that I have a twin plate metal clutch you would expect this to still be a problem but it is not.
The way I did it was a bit of a cheats way and not the best method but it worked.
Tony
Old 05-16-2012, 08:50 PM
Thanks for the update.
Old 04-12-2013, 04:44 AM
Okay bit of a update as you are aware I adjusted my idle manually. Anyway or reason that are a long story not worth telling I decided to experiment with the Subaru Select Monitor and compare the reading on the ECU.
Comparsion was between
stock standard 92 Auto SVX
My Manual 1995 6 speed set up car (the one I manual adjust the idle on)
When I compare the two out puts surprise surprise I find that the Auto shows the "IDLE VALVE" ON when the car is idling.
The 6 speed shows it OFF and there is nothing I can do to get it to go on
In the manual in the section on Fuel Injector System, there is a table "Output Modes of Select Monitor" Down the table it shows FA0 over the next page it list all the outputs under this section it shows idle switch ID. So that is the sucker that is not turning on and letting the car idle.
So team what happens to turn this on, any ideas.
Tony
Old 04-12-2013, 07:41 AM
'E''s Avatar
'E' 'E' is offline
Could it be something the tcu turned on and off when it was in park or neutral and therefore no load on the engine?
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
Old 04-12-2013, 09:39 AM
Tapani Tapani is offline
If I understand correctly you prevent the butterflies from closing? If yes, then could it be that the ECU thinks that your are not idling (against the BF stops), but pressing the pedal and it closes the idle air bypass?
/T
Old 04-12-2013, 01:45 PM
Figured this much out,
TPS output voltage has to be below .4V or the idle valve is'ent turned on. My TPS was reading .6V.
At this point it did stop the stall (I had adjusted out my opening of butterflys).
I need to figure what happens when the idle control valves opens and see if the so call valve is opening.
Anyone know with certianity which valve it is.
Tony
Old 04-12-2013, 01:49 PM
Tapani what you say is sort of correct with the stop working I had the TPS reading .85V with them adjusted out, it read .6v still no valve opening. so I adjusted the TPS itself.
Still need to see if the gear change sensors have and effect.
Tony
Old 04-12-2013, 09:06 PM
The ECU also looks at the engine rpm - not only the TPS.
If you want to leave the butterflies a crack open - you may try setting them so that the engine idles below the normal speed... this way it acts as a "backup" only and lets the ECU adjust the speed? What do you think?
/T
Old 04-12-2013, 11:08 PM
Tapani that seems to be correct and possiable temp.
What we know,
TPS voltage has to be below .4V,
Idle around 1,000 not sure if this change based on heat,
But it still won't idles normally without me cranking the butterfly open slightly.
Got me stuffed.
Tony
Old 04-13-2013, 01:48 AM
Okay can't seem to get the "Idle Switch" to turn on again but I have got the car to idle better. As part of checking I found that the left O2 sensor wasn't working, at this time the car had no hope of idling. Found the main harness wires broken so repaired that a install a different O2 sensor. Still didn't idle checked the monitor and the left back was over injecting by 38%, bad sensor.
Replaced the sensor and now it idles a bit rough but it does idle which is a surprise, its dark now so I will have a look tomorrow and see what more I find.
Tony
Old 04-13-2013, 07:58 AM
You do know that the O2 sensor wires (from the sensor upto the connector) may not be repaired by soldering, yes? The sensor gets the ambient O2 reference thru the wires - inside the insulation. Weird, but true.
You said "main harness" so probably you were fixing another part of it - not the sensor wires themselves.
/T
