Old 03-18-2007, 10:44 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Strange misfire, HELP ASAP
I just got done putting a motor with fresh water pump, thermostat, idlers, all belts, plugs, and so on plus 4.44's into Wannarace928's SVX. It seems to run perfectly fine when first started and allowed to idle and it will rev up fine in "P" if you don't go over 3,500 RPM's. If you do go over 3,500 RPM's, When you let off the accelerator it will start missing a cylinder and either stall or nearly stall. It will then miss and idle rough for about 15 seconds and then the cylinder starts firing again and it runs perfect. When driving say 55 MPH, It will not accelerate when you floor the pedal, It just drops into second and revs. You have to slowly press the pedal down and keep it in 4th gear to accelerate. Also, When in "P" it will only rev to 5250 RPM's maximum. I checked the codes and got a code 31, So I changed the TPS and the code went away and there are now no codes. Any ideas?
I'm leaning towards a coil right now and I plan to swap all 6 first thing in the morning and see what happens.
Old 03-19-2007, 12:56 AM
92svx95 92svx95 is offline
If you test the coil plugs with a metal object(screwdriver) at night or in a garage with the lights off then you can for sure find out if a coil is bad. It's ok to use a flashligh
Old 03-19-2007, 03:02 AM
It is presumed that you correctly set the TPS with a voltmeter when you installed a replacement. If not check for advice in the "how Too" section.
Edit P.S. Sorry I did not take notice that you are a member with in depth experience.
Old 03-19-2007, 07:00 AM
Budfreak's Avatar
Banned
Yes Trevor, I swapped out the TPS and set it to .50 Volts and I also swapped the MAF. It seems this problem as happening when she brought it to me, So now I'm looking into the computer and fuel pump.
Old 03-19-2007, 09:01 AM
also, if you can get it to miss consistantly, unplug the injectors to find the mystery cilinder. Sounds like the same problem I am having with my teal and I still need to change my fuel pump. It pretty common as many people are talking about it. I changed all my injectors and my fpr and still nothing. Changed the MAF and reset my TPS. I really think it is just and overpressurization of the fuel system and could be caused by something in the tank... presuably the fuel pump. I bet if you disconnect the fuel lines and let the system purge, it will run well for a little while then begin the start acting up when the fuel pressure gets too high again. Good luck
Old 03-19-2007, 02:06 PM
Budfreak's Avatar
Banned
That's exactly what I'm thinking also. I ran a fuel pressure check and it is at over 60 PSI when running on the return line with the regulator hooked up. This motor was just put in and the old motor was doing the same thing, So I too am leaning towards changing the fuel pump. I'm thinking it has too much pressure and is running so rich that when I rev it above 3,500 RPM it fouls the plugs temporarily and causes the miss. It is even worse when cold I found out. When I rev above 3,500 with the engine cool it will immediately stall and simply refuses to start again without the gas halfway to the floor.
Old 03-19-2007, 02:17 PM
wannarace928's Avatar
wannarace928 wannarace928 is offline
Send a message via AIM to wannarace928 Send a message via Yahoo to wannarace928
Classic SVX
Now it was doing something very similar to that for me before I brought it to you, some mornings I would have to hold the pedal ALL the way to the floor and hold it there for a short while even after the car started because the RPM's would be down at 0 and it would sputter sputter sputter until it got a little warmer then the rpm's would suddenly REV and then I could slowly let off the gas pedal until the rpm's evened out. If I didnt slowly let off the gas it would instantly die then good luck starting it.
Old 03-19-2007, 10:01 PM
Budfreak's Avatar
Banned
Ok, so far I've replaced the following:
MAF
igniter
fuel filter
fuel pump
ECU
TPS
I've checked for vacuum leaks and so on but haven't found anything out of the ordinary. The ECU is throwing no codes. I installed new idlers and a timing belt and I know the timing is right as I tripled checked, plus it runs great until it gets to about 3,500-4,000 RPM's. Runs very very quiet and smooth when idling. I can't think of anything else to replace that would be causing this problem as it was happening before I swapped the motor and tranny meaning it is not any sensors located on the motor and has to be something electronic or fuel related located elsewhere. But what????? I'm lost on this and tired of swapping parts. Anybody have a select monitior for sale?
Old 03-19-2007, 10:55 PM
Curly one.
Trying to jog your thoughts. --- Take into account any and every item you may have transferred from the original motor. You have probably done so but as said, a memory jog.
Old 03-19-2007, 11:02 PM
Budfreak's Avatar
Banned
Curly one.
The only things transferred were the accessories and a few vacuum lines that had been cut on the new motor and were swapped from the old one. The motor came with it's own coils and sensors ready to run except for the accessories.
Old 03-19-2007, 11:48 PM
This may or may not help, and will certainly not make you happy. As a fact I have found in the electronics arena, that what one would think very, very, very unlikely can occur. In other words the two motors may have had a similar sort of problem.
I think that right or wrong you must consider coils plugs, boots and HT leaks.
Please be sure I am trying to help and don't get mad, if you do not have success, as a result of my meddling.
P.S. Electrickery has often driven me mad. Nothing permanent mind you.
Old 03-20-2007, 07:09 AM
Nomake Wan's Avatar
Retired
Probably totally off-base on this one... but has the ECU been reset since you swapped motors? Maybe it's just not reading one of the sensors correctly...
Old 03-20-2007, 09:01 AM
GOT2HAVESVX's Avatar
GOT2HAVESVX GOT2HAVESVX is offline
What blue lights?
Send a message via AIM to GOT2HAVESVX
Its on his list as being replaced. Does it still need resetting?
Life begins around 70 MPH and stops when you dont see the flashing blue lights anymore!
Scott & Audrey's Subaru SVX's
1995 Green
1992 Black
Old 03-20-2007, 09:22 AM
Whatever you say Trevor....
Old 03-20-2007, 09:43 AM
Budfreak's Avatar
Banned
Yes, I thought of that also, But didn't have the time or energy to swap the coil packs and the miss isn't consistent long enough to trace. I always appreciate your advice Trevor, Your a smart man and a great value to this community. I'm taking the car back to her today and she has a friend who can hook it up to diagnostics and find the exact problem possibly and then I can go right to it and fix it. It also decided to start a small leak yeterday out of the brand new rear main seal, Just as a little bonus for me I guess.
The second I find a select monitor consider it sold. What a value it would have been on this one.
