Old 02-04-2007, 12:09 PM
Ken92SVX Ken92SVX is offline
Lower control arm bushings worn?
I have a clunking noise when going over bumps and around corners that I think are caused by the lower control arm bushings which appear to be worn. Using a pry bar I can see that the bushings are cracked around their circumference. I have replaced the ball joints which were worn; this helped with the problem somewhat.
Is this a typical problem with the control arm bushings? Does anyone have any used control arms for sale that are in good shape? Is there a group buy available yet on the control arm bushings?
Thanks, in advance. Ken
Old 02-16-2007, 06:50 PM
Is the control arm bushings a common problem???
I have not got a reply on this yet.
Please someone reply.
Old 02-16-2007, 11:06 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
there was a group buy on control arm bushings..
you would have to go to the group buy forum or pm earthworm to see if there is any avaliable.
Old 06-01-2007, 08:07 PM
Once there is enough demand there will be a group buy for these bushings. Check the group buy forum and add your name to the list if you are still interested.
Old 06-03-2007, 10:15 AM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
thumps over bumps could mean sway bar links are worn grab them shake them and see if there is any looseness in the parts
- John
