Old 04-01-2002, 01:28 PM
phoenix96's Avatar
phoenix96 phoenix96 is offline
SoCal SVXer
Send a message via ICQ to phoenix96 Send a message via AIM to phoenix96 Send a message via Yahoo to phoenix96
SVX Sighting - In My Driveway
Yes, it's here. My quarter year quest has ended
I am now the owner of a 1992 Black (well it will be after it's washed lol) SVX LS-L.
Anyways, I've only found a couple minor problems with the car so far. The first is the seatbelt. It's got the automatic shoulder belts. The passenger side seems to work fine, but if I turn off the car before opening the door on the driver side, the belt doesn't retract, and I have to turn the key to "On" before it will.
The other thing is that the hood doesn't stay open. I remember reading a couple months ago about the hydraulics going bad, but I was unable to find that post. Is there an easy fix for this?
phoenix96
2006 Legacy GT Limited · 2006 Outback 3.0R VDC · 1992 SVX LS-L
Old 04-01-2002, 01:33 PM
phoenix96's Avatar
SoCal SVXer
Oh, and another question I had is more out of curiosity. The VIN # on my car ends with 107999. What does that mean as far as its production number? It was manufactured in 12/91.
phoenix96
Old 04-01-2002, 02:06 PM
SHISVX SHISVX is offline
glad the wait is finially over. i wish you luck with your car. i can't help ya with the problems, but i just wanted to say congrats!
Kelli
Old 04-01-2002, 02:25 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Congratulations, Andrew! Go to Lwin's (Seraph's) personal locker for a VIN decoder chart.
There is no real "easy" fix for the hood struts, other than replacing them, or, using a broom handle as a prop. There are some little "clicky" things available at some autoparts and JC Whitney stores that serve as a prop for the struts (JC Whitney #13ZZ4688T)
The seat belt problem could be caused by a sensor. Try cleaning the tracks, and spritzing just a little WD 40 in the area where the belt comes to a rest. There's a sensor that sometimes acts up. If that doesn't work, take the trim piece off the window and manually clean the area. That might help.
Again, Andrew, Congratulations.
Randy Johnson
Mike Davis -- at Reading VI
Old 04-01-2002, 02:56 PM
Mr. Pockets's Avatar
Moderator
Congrats, Andrew - I wish you many thousands of happy miles in your SVX.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 04-01-2002, 03:23 PM
Green1995SVX
Re: SVX Sighting - In My Driveway
BIGGGG congrats!!!
-Mike
Old 04-01-2002, 04:22 PM
wawazat??'s Avatar
Yeah, I'm still around
Welcome Andrew!
Mine was also built 12/91 and last 6 of VIN are 108085, just a few away. Hope you enjoy your new (to you) car!
Todd
Down to none
Old 04-01-2002, 06:22 PM
phoenix96's Avatar
SoCal SVXer
Thanks for the congrats, everyone. I'm definitely excited, since this is the first car that is really mine
I jiggled the seat belt around a little bit and it started moving by itself, so I'll probably try Randy's suggestion. I did notice one other problem, the power antenna doesn't go down all the way. It extends fine and the radio reception is great, but when it retracts there are 5 inches left sticking out. I tried pushing it a bit to help it along but it feels stuck.
I have to say, although I've only driven the car 10 miles and no faster than 55mph, it is very smooth shifting. In my Outback I can feel a pretty noticeable thud at each shift, but in the SVX I didn't feel anything. It seemed to accelerate fine and, boy, is it hard to keep it under 40
The steering has a very different feel from the Outback, though. Much more power-assisted.
phoenix96
Old 04-01-2002, 10:07 PM
Invisible avatar
Squirt some WD40 on it & see what happens. Cured mine. Best of luck with everything else.
Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 04-02-2002, 09:54 AM
Aredubjay's Avatar
Ron.
Extend the mast fully, then, take a rag and cup it around the mast to shield the car from overspray, then, spray the mast down with WD-40. Wipe it down until you've gotten all the black gunk off the mast joints. After that, I put a couple of drops of 3-in-1 on each of the mast joints, lower the antenna and wipe off excess around the top button. That should keep it going for some time. If you don't have 3-in-1, just keep the rag cupped around the mast to shield from overspray and spray each of the joints with WD-40, lower it and wipe off the excess.
Randy Johnson
