Old 06-02-2005, 05:15 PM
91svx
5 Speed driveshaft problem
Hi
i've finally completed my 5 speed conversion using a 91 Legacy RS gearbox and running gear. My last problem well hopefully, the drive shaft is hitting the gearlever bracket. I took the bracket with rubber bush from the legacy and bolted it to the svx but it hangs too low and hits the driveshaft under acceleration. Has anyone else had this problem? or any photos of what they did so it has clearance?
Old 06-02-2005, 05:16 PM
I believe several people have used shims to increase the clearance. Fortunately, I did not have this issue.
Old 06-02-2005, 05:20 PM
91svx
Sorry for my ignorance but how could you use shims to give more clearance?
Old 06-02-2005, 05:35 PM
Shims on the driveshaft/transmission mounts to lower them slightly.
Old 06-02-2005, 05:38 PM
91svx
Sorry of course, i'd prefer a different option as the new gearbox mount makes it pretty hard to add shims.
Thanks for your help tho
Old 06-02-2005, 05:42 PM
Here's a reference thread:
Reference Thread
Old 06-05-2005, 05:11 PM
SilVerXtc
I think I had this same problem saturday when I changed my driveshaft to one from a 95 legacy. I put a couple washers to lower the driveline at the carrier bearing bracket. That solved my problem.
