Old 01-17-2005, 04:16 PM
rmjjensen's Avatar
rmjjensen rmjjensen is offline
Send a message via AIM to rmjjensen
Lightbulb Info: Gear Ratios, Speed, RPM and Final Drive for trans swap
I'm still trying to get my transmission stuff together for a swap. Hopefully my auto box and diff can hold up until summer time. But, I decided to calculate what the speeds and RPMs would be with various gear sets and final drive ratios from subaru transmissions. I must say I like the new 5EAT the best but I'm sure that would cost a pretty penny to install and be extremely difficult. Plus - the final drive ratio seems low.
Figured I'd share this with you guys:
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing
5-Speed Status: DONE!
Lambo Door Status: On hold but will be a success
04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk.
The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash
Old 01-17-2005, 04:33 PM
Ciscokid
Oh - I thought the SVX had a final drive ratio of 3.9? Everywhere I consult states 3.55 - which one is it?
Not that I am an expert or anything but from reading a lot on the boards I know it to be 3.545
Old 01-17-2005, 04:36 PM
Yup, 3.545
I'd still recommend the WRX 5 spd.
Our tire diameter is 24.858"
Circumference is therefore 78.09"
My gear calculations:
http://svx-iw.com/pics/gears.gif
Old 01-17-2005, 05:00 PM
lee lee is offline
I think he only counted the top (or bottom) of the tire - check by using the full value of 225 (50% on top, 50 on bottom for total height).
Old 01-17-2005, 06:07 PM
rmjjensen's Avatar
duh - I made corrections - even better yet I did the calcs for 225/40 18's and it looks a lot more respectable. I definitely like the looks of the legacy 5 speed with 4.11s
Earthworm -> Where'd that magical 0.631 6th gear come from??
3.545 definitely rings a bell .......i knew that. So this may be a stupid question - but why don't you have to swap diff gears for the WRX swap with 3.9s if it's still different from the SVX?
Old 01-17-2005, 06:19 PM
I made up the 0.631 gear. It's what would be required to match the 4th gear from the 4EAT (w/TC lockup). I'd love to be able to have a 6 spd with those specific gear ratios.
The WRX 5spd has a unique (to Subaru) 1.1:1 ratio AWD system. This gives you a 3.90 front diff and requiring a 3.545 rear diff.
3.545*1.1 = 3.9
Old 01-17-2005, 06:45 PM
mbtoloczko's Avatar
sans SVX
One more correction:
SVX 4th gear: 0.694
Its listed incorrectly as 0.64 on subarusvx.com.
Mychailo
Visit my locker
Old 01-17-2005, 06:48 PM
rmjjensen's Avatar
Well that explains it! I love just soaking in all the information from this site. You know - I might just be able to make a custom sixth gear for the SVX. We do have a CNC machine that I can use. I'd just have to do the CAD drawing, place the material into the machine and let it rip. But - I'd need solid dimensions and to know the exact material that should be used. I might just look into it.
