Old 07-21-2003, 09:46 PM
JacciMullineaux
Lightbulb check engine light
Does anyone else's check engine light always randomly comming on? Subaru says it's not a problem but something tells me thats not right because it isn't an electrical problem, i checked. Is this common?
Old 07-22-2003, 05:12 AM
svx_commuter's Avatar
Hey dude, you got a 92, check your own codes, the ECU stores them. Most likely the O2 sensors need to be replaced or the TPS or the knock sensors. The dealer is right that it is not too bad but it is an indication of sensors going bad. The codes can be checked. Search for the procedure on this, many posts.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 07-22-2003, 12:04 PM
max mullineaux
Smile thanks
Hey thanks alot i'll definitly check that out
Old 07-22-2003, 04:16 PM
ive got the same problem. happens only every so often. does punching the gas make it disappear or do you know? probably the o2 sensors, or in my case something fooling the o2 sensors.
Old 07-23-2003, 09:57 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
My self diag showed both O2's as being out, but then, the final answer was the MAF Sensor. If your car is not stalling or missing badly, it's probably the O2's.
Randy Johnson
Mike Davis -- at Reading VI
Old 07-23-2003, 11:58 AM
max mullineaux
Smile thanks
alright thanks!
