What's the "right time" to do the *strut*
i'm planning to spring for yet another set of rubber soon and just sorta wondered when the struts should be replaced. i don't want to put prima (read: toyo fz4) rubber on my SVX and then wear it out prematurely just because i didn't do the *struts*.
car runs beautifully, but i just thought i'd check and see if there are any guidelines. mine has 119K on the clock, although one would never guess it. TIA |
I would say that you are nearing the end of their useful lives. Have you tried rocking each corner and counting how many times the car bounces?
Mattski 97 LSi Ebony Pearl 130k Midlife Crisis 93 Legacy Wagon 180k Training Wheels 98 Outback 180k 98 Dodge Durango 120k Ski Bus A multitude of skis to feed my need to go faster, faster until the thrill of speed overcomes the fear of death. |
Usually right after you've done something for which you feel exceptionally proud.
Oh, you mean that other kind of "strut"....nevermind |
Have your struts leaked at all?
Mine have but still pass the bounce test. Quote:
Bounce test?
Okay, having spent most of my life driving old cars with crappy suspensions, I'm confused: how many times should the car bounce when you rock the corners? What's good, what's bad?
--Ross (earthkin) RIP: '92 SVX LS-L AWD, black over claret Nearly gone: '92 Legacy SW, 353k miles '00 Impreza Outback Sport, 'silverthorn met titanium,' 134k miles |
Re: Bounce test?
Chris SVX World Network Administrator -1993 Subaru SVX LS-L, Barcelona Red, #46, 160,000+ Miles (Sold to SomethingElse) -2011 Toyota Sienna SE, Black, 30,000+ Miles (Swagger Wagon ) -2002 BMW R 1150R ABS, Black, 26,000+ Miles (Daily Driver ) SVX Owner from February 1997 to March 2008 SVX Online Community Member since February 1998 SVX World Network Member since February 2002, Member #520 Life is a game. Play to win. The world belongs to those who can laugh at it. |
they don't bounce, although they will compress. problem is, the car seems to ride like a truck, especially over smaller bumps. maybe it's just the treadless rubber.
i'm gonna ask them to look them over (however this is done) when they put on the new tires next week. thanks, rB |
Yea...I've got FZ4s and they were crazy smooth when I bought them. They wear really well too. Grip isn't the best, I don't think, but that's OK because they are holdin' up pretty well. Anyway, I have the front end knock that many people get. I didn't really care about that cuz I can't hear it most of the time. But now, the ride is getting a little harsh, and I get some tire noise under braking. There is a little tire noise whiler driving that more or less goes away as speed increases, so I don't think it's a bearing (I've had 2 go out...I'll know the noise if it's around). I've got 120k...is this a sign of bad struts. I also occasionally get some hard pulling to the right under braking...what's that all about?
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler I don't care if Subaru says it's STI...it will always be STi to me |
struts
I replaced the struts on my car at 160k. Made a big difference in ride and handling. I didn't want to put new Yokohama avs db's on it without new struts. I went with the oem struts.
I also replace the ball joints, and the steering rack at the same time....didn't want to tear up $500+ of rubber with sloppy suspension. It was expensive, but well worth it. I'll never have to do it again.
Tom 92 Liquid Silver LSL 85 BRAT GL 81 280ZX 91 Legacy wagon 86 Pontiac Parisenne (55k) 86 Kawasaki ZG 1000 Concours 81 KZ 1000 LTD (shaft) |
how expensive?
Re: struts
The "right" time to do the 'strut' is when the band plays 'stut' music.
Larry III & The Beautiful Naviguesser '19 Tungsten Pearl Outback 3.6R Ltd...."AISHA" '08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU" '07 Gray Diamond Pearl Outback XT Ltd..."AH SO" '05 White Pearl & Silver BAJA Turbo..."AH HA" '97 Bordeaux Pearl SVX LSi..."SUBYDOO" '94 White Pearl SVX LSi..."PEARLY" '92 White Pearl SVX LSL w/touring pkg..."SVXY" '92 Teal SVX LSL w/touring pkg..."ALCYONE" '96 Polo Green LSi ... "MIDORI" '00 Black Dodge VIPER RT-10... "VINNIE" Engineers do it with precision. English teachers are novel lovers. Home: larrysingeriii@comcast.net SVX FEVER, CATCH IT AT A MEET NEAR YOU !! |
sounds good to me, Larry!
Thats the thing I'v noticed about Subarus. They don't bounce. I,v had shocks so bad the oil is all gone and the shaft is rusting but it didn't bounce. I'v seen others that arn't as bad and don,t really show any sings of being bad untill you take them off. If your car has over 100k on the original struts than I would definitlly replace them.
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
Oh, sure, say that when mine has 99,500 miles on it!
