Old 05-07-2003, 12:48 PM
96 SVX owner
can you help with my bucking ? ? ?
In warm / hot weather when I am doing slow turns I get a noise .....and the SVX bucks ....and.... clicks during the bucking as I am turning.
Is this AWD transmission ? ......differential ?? What should I do ?
---aside from trying not to turn ! ! ha ha
(I wish it was only my imagination)
Old 05-07-2003, 12:50 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
seems like diff but could be a ton of other things as well.
L
Lwin M. Maung (Member # 147)
Current SVX: NONE
Is it binding as if the tranny was forcing 50/50 distribution or does it feel more like something in the steering system?
Old 05-07-2003, 01:15 PM
alacrity024
it could be something as simple as a cv axle..
-adam
Old 05-07-2003, 01:42 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
bucking
Does the power light (96's still had them right?) show that it has a trouble code in it? It'll blink like 15 times when you start the car rather than just coming on for a few seconds.
Old 05-07-2003, 02:03 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Re: can you help with my bucking ? ? ?
Sounds like the AWD is engaging when it shouldn't be. Could be a duty solenoid "C" going bad. I rectified mine by replacing the campaign filter and bypassing the stock cooler with an aftermarket one.
A 96 probably won't have either a campaign filter or a clogged stock cooler, so your Duty Solenoid "C" is probably failing. Most times it won't throw a code. Only the wrongful engagement of the AWD.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 05-07-2003, 02:22 PM
96 SVX owner
Smile Hey ...I like this site -- after my 1st posting - i got all the info ..thx
Old 05-07-2003, 06:00 PM
Stick the FWD fuse in the fuse box to disconnect the AWD system. If the trouble goes away it is the C solenoid, If it does not, it's some thing else.
Old 05-07-2003, 06:21 PM
SVXPILOT SVXPILOT is offline
Have you changed the fluid. Mine started to bind when turning at parking lot speeds shortly after I bought it. changing the fluid stopped the binding. I now change the fluid every 10'000 miles. the clicking could be a bad cv joint.
Old 05-07-2003, 07:13 PM
vkykam's Avatar
vkykam vkykam is offline
The Road Less Traveled
Just a minor aside...
If the FWD fuse is in, but the FWD light does not light up on the dash, it's probably the Duty Solenoid C as well. But in this scenario, the TCU should have registered the problem, and you should see a blinky Power light.
VK
Old 05-08-2003, 06:33 PM
VK
Yes it depends on if the solenoid has failed electrically or mechanically.
If it failed electrically the TCU will post a code. I have opened up a mechanically failed C solenoid and found that the return spring that returns the armature has broken up, jamming the armature from opening fully, thus applying pressure to the clutch.
