Old 04-23-2003, 09:21 AM
knight'92
Cant Figure out the problem
Okey... driving down the road.. I hit the gas to pass someone.. and BAMM
I hear a loud pop.. then I loose power.. and the engine tone changes completely..
and I can hear a rattle coming from the passenger front... in trying to figure out what it was.. (before taking it to the guy that works on my car).. I noticed, that, when I hit the gas... the car didnt have enough power to get over about 4x RPMs..
After taking it in.... They have checked for a clogged exhost, he checked the timing and the timing belt, he checked each cylendar for compression..and who knows what else.... everything checks out fine.. but the car still has no power
any ideas ??
thanks guys !
Old 04-23-2003, 09:25 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Sounds like the front diff has gone and you're in "limp home" mode. Just a guess.
Randy Johnson
Mike Davis -- at Reading VI
Old 04-23-2003, 10:02 AM
knight'92
hey, Im all for good guesses!.. thanks
Im up for all good guesses and suggestions
Old 04-23-2003, 11:47 AM
lee lee is offline
I've had the front differential die. You do get a loud noise as Aredubjay suggests. But that shouldn't have any effect on engine power.
I have seen spark plugs blow out their core, but that was mostly on big block US engines. And one presumes if a compression test was performed they would have noticed a spark plug with no ceramic.
Is the "check engine" light on? You can do a search for the diagnostics on this forum and check that for free.
Old 04-23-2003, 12:14 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
My guess....fuel pressure
Fuel pressure may be lacking, or one or both of the filters may be clogged. Testing is pretty easy, so I'd check it out.
Good luck!
'20 Honda Ridgeline
http://www.x35design.com
Old 04-23-2003, 01:19 PM
sfsvx's Avatar
sfsvx sfsvx is offline
Yeah, it's a poodle - so what?
Re: My guess....fuel pressure
Good luck!
That sounds right for the no-power situation, but what do you suppose caused the pop?
Dick
1999 Legacy GT 30th Anniversary Edition
2001 Outback Sport
Old 04-23-2003, 02:18 PM
Aredubjay's Avatar
I'm not certain, since I've never had it happen to me (Thank God!), but, from previous posts I've read, the "Limp Home" feature retards your ability to go too fast. (Yes, Rob, I said "retards," but, it's acceptable in this context. )
Could someone who's actually had to use "Limp Home" mode speak to this? Or have those who've HAD to use it, gotten disgusted and sold their cars?
Randy Johnson
Old 04-23-2003, 05:51 PM
Subafreak's Avatar
Superbeast
The important question is. Is the check engine lite on, or is the power mode lite on? From the sounds of it low fule pressure could be a problem or posibly a bad mass air sensor.
Old 04-23-2003, 09:05 PM
knight'92
OK.. here is what the machanic found
the "pre" muffler under the car, apparently blew out, and clogged up
ie: loud pop, and then loss of power, due to the exhaust clogged...
he is going to remove the pre-muffler, and just replace it with a pipe..
he checked the cat, and the muffler, those are ok, and not clogged..
so hopfully tomorrow, I will be able to let you guys know, if that fixes the problems.. I will post somthing, as soon as I know for sure..
thanks for your suggestion.. if this doesnt fix the problem. I will look into what you guys suggested..
(oh, and btw.. the check engine light, never came on.. )
Old 04-23-2003, 09:46 PM
Stevebsy's Avatar
Administrator
Limp home only comes into play when the TCU thinks everything has gone to hell and doesn't know how to shift, or is missing some required inputs. If the front diff fell off, it wouldn't know....
Quoting FSM 3-2.24
"A fail-safe function is profided to maintain driveability even if trouble should occur in the vehicle speed sensor, throttle sensor, inhibitor switch, or any of the solenoids."
'20 Honda Ridgeline
Old 04-24-2003, 04:39 AM
A clogged cat will do the very same thing. Hope you did not have to drive too far with it. If gas can't get away, it creates a lot of heat, but hopefully you will not have melted the platinum out of your cats.
J/K
Old 04-24-2003, 08:13 AM
knight'92
No, I just had to drive it about 5 miles.. if that...
Old 04-24-2003, 11:59 AM
I was only joking Knight, but it is the sort of thing you would not want to drive too far on.
Old 04-25-2003, 01:00 PM
knight'92
well I got the car back today... everything seems to be great !
yay!
now all I need to do, is do that resister mod and Im good to go
Old 04-25-2003, 02:35 PM
Thumbs up
Glad all is OK!
Think positive thoughts, keep your car happy.
