The Mercedes Club is at the "main" Summit Course on May 21, and I am kinda committed for that event, but a mini-meet on the 19th would be interesting! And I would venture over to the Shenandoah circuit to find you between runs and instructing. Let's be sure to touch base as the time gets closer ..... Harry
newsvx 1992 SVX LSL, #1215 1997 SVX LSi, #370 "I live with fear every day. Sometimes she lets me go racing." "Getting Older and Slower" Locker: http://www.subaru-svx.net/photos/user.php?newsvx |
Dan,
I just checked the R32 site and it is 19/20 May, not 20/21 May. Maybe you could run three days?? Myself, I couldn't afford to do so ..... Harry
Harry:
You're right. It is May 19-20. It is Saturday and Sunday, though, which is most important to me. Funny how I got the date right on the party request to Tom. Priorities. Anyway, hope you can drop by the track sometime that weekend. Dan
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
Be sure to remind everyone the week prior to the event! BTW, you'll like the Shenandoah Circuit!! Very challenging!! And FUN! Harry
here is to hoping I have enough cash to make it out
Tom |
I hope we see you there, Tom!! Harry
Tom:
If you want to go, I would recommend that you go ahead and get on the novice waiting list. It might open up, and you can always cancel. If you wait to the last minute, I'm pretty sure you won't get a slot. Dan
I will try and get to that tonight, Thanks Dan
Tom |
