Old 07-18-2005, 09:49 PM
sicksubie's Avatar
Need to know soon! '05 2.5RS tranny, will it work?
I have an opportunity to buy a 5spd tranny from a 2005 2.5RS. If I can't do it tomorrow the guy will be leaving my area and taking the tranny with him. Will this tranny fit?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 07-18-2005, 10:47 PM
mbtoloczko's Avatar
sans SVX
Yes. If you can, get the clutch, flywheel, clutch master cylinder, and pedals too.
Mychailo
Visit my locker
Old 07-18-2005, 10:51 PM
SierraSVXer SierraSVXer is offline
tranny fit
Phone Subaru auto recyclling [800] 638-5773 Tony will know
i believe you have to redrill some holes ?
Old 07-19-2005, 10:24 AM
AvPPoW AvPPoW is offline
youll need the rear diff too
Old 07-19-2005, 12:17 PM
MaxImUmZ MaxImUmZ is offline
On a SVX board with a Z31 name
Send a message via AIM to MaxImUmZ Send a message via Yahoo to MaxImUmZ
Maybe dumb question, but why?
1995 Red LSi
Mods: ECUTune Stage One, Smallcar shift kit, removed side SVX badges(weight reduction )
Future plans: Alcyone emblem, black out taillights (Not that I think it looks overly good I just like people having no idea what it is and want to add to the confusion)
Old 07-19-2005, 12:38 PM
The 2005 2.5 RS has a final drive axle ratio of 4.11 (same as my 2002 rs tranny). The SVX/WRX use 3.90, so if you got a WRX tranny, you could use the stock SVX diff. The rear diff has to match up to the tranny your going to use so you need to get the RS and swap the internals to the SVX diff case.
Cheers,
John
Old 07-19-2005, 12:51 PM
Earthworm's Avatar
Meow!
While it's true you can use the WRX tranny with the stock SVX rear diff to be accurate the WRX/SVX both have a 3.545 rear diff. The WRX front diff is 3.90 and the AWD in that tranny has a 1.1:1 ratio to make everything work.
The WRX tranny is the best choice for high speed cruising.
Old 07-19-2005, 08:38 PM
sicksubie's Avatar
Here are the numbers from the 2005 2.5RS
1st 3.545, 2nd 2.111, 3rd 1.448, 4th 1.088, 5th 0.78, Final 3.9
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 07-19-2005, 08:39 PM
sicksubie's Avatar
So I'm under the impression that you can use the stock rear diff
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 07-20-2005, 10:05 AM
I'm pretty sure it's still 4.11, make sure your not looking at the rex. Post your question on NASIOC
Old 07-20-2005, 10:41 AM
I have a spare 4.11 rear diff if you end up needing it
Old 07-20-2005, 01:18 PM
Earthworm's Avatar
Meow!
The WRX doesn't have a .78 5th gear. It has .738 instead.
Old 07-21-2005, 09:24 PM
sicksubie's Avatar
This isn't a WRX tranny! It's a 2.5 RS tranny and I'm under the impression that there are differences.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
