A little help with engine removal...
So last weekend I decided to finally pull my engine so I could replace the head gasket that went back in March. I started taking everything apart, and everything was going more or less OK, until I got to the point where the engine had to separate from the transmission so it could come out. Here is the car as it currently sits:
I removed everything holding the engine and transmission together, but I can't get them to separate no matter what I do. What am I missing here? Is there some kind of trick to this that I don't know about?
Ebony/Gray '92 LS-L, @123k - bought 01/17/2010, parked for 10 years. Getting back on the road. Last edited by Black88GTA; 10-24-2010 at 05:21 PM. |
Re: A little help with engine removal...
Did you separate the engine mounts from the crossmember?
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
Yeah, I have it so that when I hoist the engine up I can move it around. It's completely free of the car , but won't break free from the transmission.
Ebony/Gray '92 LS-L, @123k - bought 01/17/2010, parked for 10 years. Getting back on the road. |
you unbolted the flexplate, right?
Yep...got the 4 flexplate bolts, both starter bolts, the nuts on the studs at the bottom, and the remaining bellhousing bolt on the top passenger side. I have a full set of the factory service manuals, and went through the procedure top to bottom, and made sure to remove every fastener it refers to, but there must be something I'm missing...
The tranny was upgraded to a 4:44 less than 2 years ago, and the car has probably seen ~10k miles since then, so it shouldn't be seized in there or anything like that. I just can't figure it out.
It may help to loosen your tranny mount. I suspect the transmission is restricting the engine from lifting enough to clear the bushing studs from the crossmember. You need the studs to clear so you can slide the engine studs (threaded into the bottom holes on the backside of the engine) out of the bellhousing on the trans.
BFH, flathead screw drivers of various sizes, and prybars... Even if the engine and trans were apart just months ago, unless you put antisieze, and even if you did, it still will sieze back together. Its just what happens when you mix aluminim and steel
