Old 06-11-2011, 08:01 PM
Huskymaniac's Avatar
Uses the ignore feature
Contact cleaner
Is CRC the best? Has anyone ever had O2 sensors give a slow response code due to dirty contacts? I put a new O2 sensor in last fall and it occasionally trips a code for the same slow repsonse error. I bought Bosch sensors so they should be high quality. The fact that it is intermittent says contacts to me.
Tony
Old 06-12-2011, 06:18 AM
dennyo dennyo is offline
Re: Contact cleaner
My 96 has been doing this for a few years now. I've tried bosch and ngk sensors,cleaned all the contacts except at the ecu,cleaned the injectors and nothing has worked.I even cleaned the bungs so I know they make good contact on the cats.It returns every 2 drive cycles. Just like the FSM say's it will. I just clear it when it pops up.next step is exhaust. It runs fine but uses a little more fuel than normal.Btw, the code I get is po145. Good luck and let us know if you figure it out.
Old 06-12-2011, 07:32 AM
Re: Contact cleaner
I replaced bank 1 sensor 1 and it has been fine. I replaced bank 1 sensor 3 and it still gives me this error intermittently. I can't remember which code it is, numerically, but it is the slow repsonse one. That usually means the sensor needs to be replaced but this is a new Bosch. I suppose it could be a faulty sensor but I have also heard it could be bad contacts.
Tony
Old 06-13-2011, 04:58 AM
michael's Avatar
michael michael is offline
What Potholes ???
Re: Contact cleaner
Was it with a Bosch Universal or OE style?
*Yea 2000 posts!
Wanted: Steering Wheel
Old 06-13-2011, 05:59 AM
Re: Contact cleaner
*Yea 2000 posts!
It was the one with the connector on the end, not the bare wires.
Tony
Old 06-13-2011, 08:56 PM
michael's Avatar
What Potholes ???
Re: Contact cleaner
I had bad luck with the universal type (bare wires). OEM type should have been fine
Old 06-13-2011, 09:39 PM
Re: Contact cleaner
What kind of bad luck?
Tony
Old 06-14-2011, 05:56 AM
michael's Avatar
What Potholes ???
Re: Contact cleaner
Keep in mind mine is a 92. I was getting a CEL after the new one was put in, I forget what code exactly.
Old 06-14-2011, 07:20 AM
Re: Contact cleaner
Did you eventually resolve the issue? If so, how?
Tony
Old 06-14-2011, 08:52 AM
michael's Avatar
What Potholes ???
Re: Contact cleaner
I returned the sensor for a new one.
Old 06-24-2011, 07:31 PM
Re: Contact cleaner
I had the contacts cleaned and greased with contact grease. If that doesn't work I am going to contact Bosch for a replacement. But I am wondering if the problem isn't related to mismatched O2 sensors. Both bank one sensors are now Bosch but I am guessing that the bank two sensor is OEM.
Tony
Old 06-25-2011, 10:57 AM
Re: Contact cleaner
OEM is Bosch.
Old 06-25-2011, 11:08 AM
kwren's Avatar
kwren kwren is offline
Re: Contact cleaner
Originally Posted by Huskymaniac View Post
I had the contacts cleaned and greased with contact grease. I am wondering if the problem isn't related to mismatched O2 sensors.
I have been wondering when you are going to "bite the bullet" and get that head gasket taken care of...
Hang in there, Tony!
Keith
Old 06-25-2011, 07:38 PM
Re: Contact cleaner
Keith
Fine people, I will edit my response. But I still ask...can someone finally ban this jerk for good? Trevor was a prince of congeniality and a great addition to the community compared to this miserable excuse for a human being. And to think this guy facies himself a wise old man. What great philosophical teachings have ever said it is wise to instigate and antagonize other people to drag them into your misery so you will have company?!?!?!?!
Tony
Old 06-25-2011, 08:40 PM
Re: Contact cleaner
OEM is Bosch.
That is not consistent with what I have read in other threads and my remaining OEM sensor does not look like the Bosch sensor. I think denyo said in another thread that others have claimed that the ECU seems to only like OEM sensors and that NGK and Bosch have caused him the same issues. The Bosch sensor I used for Bank 1 Sensor 1 seems to be working fine as a replacement. This appears to only be an issue with the extra sensor (sensor 3) that only the OBD2 cars have. If the code returns I will probably swap sensor 2 and sensor 3 to see what happens.
Tony
