Old 05-03-2022, 04:17 AM
BobSVX96 BobSVX96 is offline
pot hole causes loud clank
Hi forum,
I have a very loud CLANK from underneath the car when I hit a large pot hole. This only seems to happen when traveling 25-35mph. It happens whether the pot hole is on driver or passenger side.
Never happens during parking lot speed bumps (I purposely drove over a medium-sized speed bump 10 times, alternating the wheels to see if it happens on 1 side or the other. Nothing happened.)
Never happens on the highway. Smooth & reasonably quiet.
Thoughts?
Thanks, Bob.
Old 05-03-2022, 07:05 AM
SVX_MY_BABY's Avatar
Re: pot hole causes loud clank
Callipers?
Peter
Old 05-03-2022, 10:52 AM
irox irox is offline
Not sure what is causing your clank, but I've had a couple of 'clanks' in the past I can share.
- One time was a bent stabilizer bar link.
- Another was a worn CV joint.
- Another due to a failed wheel bearing that was spinning it's outer race, this causes the wheel to 'wobble' when hitting pot holes and hit other components.
If everything has been quiet it's probably not the wheel bearing (usually a constant noise) or the CV (you would usually hear clicking on slow sharp turns before it's loose enough to clank about).
Old 05-03-2022, 09:32 PM
Thanks for the responses.
SVX_My_Baby, if it was a caliper, wouldn't I also experience (1) a pull to the left or right under braking...or...(2) leaking brake fluid...or...(3) clanking when brakes engage...or...(4) degraded brake function? I'm not seeing/hearing any of these. The brakes work great.
irox, in the case of a stabilizer bar link or bushing problem, will the issue be obvious with the car up on a lift? Will the stabilizer bar move around by simply grabbing it? (I'm assuming a healthy stabilizer bar system is fairly rigid.)
I genuinely appreciate it, guys. Thanks,
Bob.
Old 05-04-2022, 03:26 AM
The caliper issue usually causes a constant rattle on bumps and especially washboard dirt roads. The brakes still function normally.
If it's a single clank I would be looking for a something large which is loose and contacting another part when jarred by a large bump.
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V,
Old 05-04-2022, 09:45 AM
Subaru oldtimer Subaru oldtimer is offline
Mine experienced similar issues and it was a dead strut. Have you checked those?
Rick
1996 SVX LSI Bordeaux Pearl 222.600 and going
Old 05-04-2022, 10:30 AM
The sway bar links should be completely straight without any bends in it:
https://www.subaru-svx.net/forum/att...9&d=1520325332
(My bad one next to a good one, posted to the forum a few years ago.)
