SVX stero removal?
just wondering how i would go about getting the SVX stero removed form my car?
thanxs
1992 NZDM SVX Maroonish Red/Black ( 1st car ive owned with an cd player ) Has been retired 1989 Vortex 6 Maroon 1983 RX Silver Grey 1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration |
Its pretty easy. When you park the car leave it in gear (the shifter is in the way in park) and pull the emergency brake. Pop out the ashtray and there is a plastic frame around the whole console with 2 small screws underneath it and I think you have to take the door off too, but I don't remember. But if you have some diff size screwdrivers and just poke around a bit you'll figure it out
Everything you need to know, with photos, can be found here:
http://www.geocities.com/svxdc/AudioInstall.htm .
The link Svxcess posted is spot on. All the color codes for the wires are exactly right. Some artard cut my connector off for the stereo so I had to match everything up. It's pretty easy to remove just be careful to not scratch anything. And make sure you slide the cardboard in the sides when pulling it out, otherwise it gets stuck on the trim.
One thing to be careful of selecting after market speakers, is the type with the coax tweeters mounted above the level of the speaker, as these will interfere with the factory grilles. The grilles can be forced over them as they have some flex, but the speaker will vibrate/resonate the grilles and panels at certain frequencies.
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
I do also have the "reverse" harness, if you want to restore the factory plug
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses |
