How much, and where to get?
Kay, had a rather horrible experience last night involving a rancid burning smell and my brake pedal sinking to the floor, so I took it in to get looked at. Lo and behold, the rear brake calipers are rusted into a partially 'on' position and as such are using up the pads and heating up my brake system. Figures.
Price quote was 400-something to replace the calipers and pads on both sides. And 700-something to do that plus rotors. I'm no dummy, and I've done disc brake replacement before (though not on ABS cars), so I would like to avoid this insanely hefty price tag. I know I can get replacement rotors for a good price, but my rotors actually seem fine. I can get OEM pads cheap too, so that's not a problem either. But where could I get rear brake calipers, and how much? Hopefully less than $125...? |
NAPA has prices from $52-84 per each...these are remanufactured...either way wherever you get you new ones make sure you trade the old ones in because they are worth a core value!!! My question now is...di you actually see for yourself that they were rusted? The pistons (is that what they're called?)may have run out of grease and without that lube this could have made them "stuck" anyway the link below is for calipers at napa. I went to their site because they have locations nationwide so I figure wherever you are there is prolly one close by and if they don't have them in stock they usually don't take a long ass time to ship.
http://napaonline.com/masterpages/NO...Rear&VehCode=Y |
Also the replacement is super easy so let me know if you need any info on that. Even for a first timer it shouldn't take more than 2 hours tops!
Yes, I did inspect them myself and yes, they are quite rusted. It's pretty nasty. Thanks for the info. There's a Napa place not too far from here... I'd just have to take a different car.
You are having a string of problems. My sympathies. But, you want to know that rusted calipers don't account for your pedal going to the floor. That would be a leak. Either external and you're losing fuild, or internal in the master cylinder, no fuild lost.
Rusted calipers account for brakes being constantly on which accounts for heat building up in my brake system. After driving it a while, that'd make the fluid heat up... and fluid boiling does account for pedal going to the floor. And that's backed up by my brakes working fine right now, after the whole system has cooled overnight. Just driving it to Midas made the burning smell begin to return.
Rear Brake Pads
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! |
dcb |
