Old 01-07-2007, 07:18 AM
95greensvx's Avatar
95greensvx 95greensvx is offline
Purge Control Solenoid
I recently checked the codes due to my check engine light coming on and I got a code for a Purge Control Solenoid and I am not quite sure where this is located at on my car. If someone could point me in the right direction that would help me out greatly. Thanks in advance.
Old 01-07-2007, 01:59 PM
Trevor's Avatar
Trevor Trevor is offline
You will find a black canister, engine compartment, front left, with two flexible tubes connected to it. Follow the tube going towards the engine. It is connected to the Purge Control Solenoid valve at the first connection point.
Trevor, New Zealand.
Old 01-07-2007, 03:59 PM
95greensvx's Avatar
I just went out and looked and are you referring to the black canister, front left engine compartment, next to the radiator? That has two tubs running out but both run into the engine and underneath the tops of the intake manifold, if that is it then I'll look further tomorrow when it's light out. Thanks.
Old 01-07-2007, 04:58 PM
Trevor's Avatar
Yes, you are on the right track. I agree things are rather obscure and you will need good light.
Old 01-07-2007, 05:01 PM
DarknessofDeath's Avatar
DarknessofDeath DarknessofDeath is offline
Inhabitant of Darkness
isn't that the one under the manifold itself? i had to replace that one. costs $$
1992 Subaru SVX LS~L Ebony Pearl
1992 Dodge Stealth R/T Firestorm Red
1992 Subaru SVX LS~L Pearl White
1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD
2007 Subaru Legacy Spec B. Diamond Grey Metallic
Old 01-07-2007, 05:19 PM
Trevor's Avatar
It is certainly hard to get at and you are probably right.
Old 07-22-2009, 01:49 PM
Mike Mike is offline
Re: Purge Control Solenoid
There is a third hose attached to the bottom of this canister. Mine goes no where, do you know where the other end of this hose attactes to?
Old 07-22-2009, 02:18 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Its not supposed to connect to anything, its just a vent, usually it just plugs into the hole in the firewall.
Old 07-22-2009, 03:02 PM
NiftySVX NiftySVX is offline
Purge control solenoid! I remember when there used to be a box full of these at the dealers. They used to go bad all the time.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
