Getting engine ready for 100 shot
My engine currently has 194k miles on it. It had a sticky lifter that was resolved with MMO and it has an oil leak that needs to be fixed. Id like to install a 100 shot this summer. With an engine with these kind of miles what would you gurus recommend be done to the engine to make it safe to run nitrous and stay running for many more miles?
Should I replace the headgasket? replace piston rings and hone the bores?
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. |
don't use a 100 shot... 75dry has been the safetly limit for most without reducing timing. If you are going wet... 100 shot should be ok but make sure the engine is in good running condition
Tom |
I was planning on a wet shot. I know these engines have been known to go 250k+ but what areas should I look to replace just to make sure it lasts for many more miles. What usually goes on these engines first?
If you want your motor to last longer, do not put nitrous in it
Tom |
Unless you plan on replacing your tranny with the police special platinum edition, I wouldn't go there.
Robert Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me. Update: 09 January, and still not in jail! Wassup?? 1992 Teal LS-L - 160k (Now new and improved with perfect paint!) |
err read that up there then i saw where you said a 5mt. the 5mt failed due to power... and the stock motor has more power(torque) then a 5mt can handle imo. |
i was kinda hoping to offset the decrease in life from nitrous by replacing the parts that see the most wear from age. But im not sure if i should reconsider.
Throw a 5mt in there first.
Stephen |
I may just save my money and buy a used motor if the current one blows. I know the blocks on these motors must be split to reach the main bearings, does this require a special tool?
I was considering doing a fresh rebuild of all seals, head gaskets, rod and main bearings, piston rings, and maybe having the rods shotpeened.
not to be a dick... but do you know what that will take to do?? Do you know how much parts alone will cost?? Might make u reconsider
Tom |
i dont take offense at all. I was looking at prices at for all seals, rings, and bearings it looks to be about $1000. Buying an engine with over 100k on it seems to be almost 1000 shipped so Im just weighing my options. Id feel alot more content with a fresh engine.
but who would rebuild the engine?? it will rake more than just parts including getting the block/heads milled. glaze broken... etc
Tom |
