Is there any diff from other FWD trannys that will fit ares?
Ok i have two trannys that both need the ring and pinion gear set which are parts that are discontinued. But is there any other car that has the same diff that wiil fit are tranny? Or does any one know of a ring and pinion gear set that would fit are tranny?
The SVX is th eonly Subaru that had a 3.54 front diff...
but any of the other 4EAT Subie trannys ring and pinion will fit in the SVX tranny, but you'll need a matching ring and pinion for the rear diff as well...
ok im just starting to learn all this stuff were is ther rear diff located at and how much do think it would cost to go that route. So what your saying is that if i get the ring and pinion for my tranny from a 4EAT then i have to also change my rear diff even if im FWD.
-Chike
You're right though, the front diff from a 5EAT wouldn't work. -Chike
Well i already have both trannys apart and i have a mechanic who well help me install the ring and pinion for free so i was going to just try to get the gears or the casing and the gears. So a 4EAT diff will fit to are tranny right
I really dont know about this but i have knoticed working on other subarus like the older legacys the transmissions look the same but im not sure if they will work.
what car does the 4.44 come out of ?
hmm i just had a problem with my rear diff i need to replace it acording to my mechanic where can i get the parts i have leather and moonroof i believe limited slip? junk yard? other models? thanks in advance!
96-98 Legacy Outback and Legacy GT are the easiest to come by with 4.44's
