Old 08-01-2009, 12:33 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
click click click...start? click click start!
so i turn the key to start my baby and she clicks...is it starter? starter solinoid? ignition switch?
help please..sorry if this is a repost..i cant search the message archives for some reason? help there too? running vista32 bit with IE8
VICSVX
94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx
Old 08-01-2009, 12:50 PM
Re: click click click...start? click click start!
search "how to do the bosch relay mod"
Old 08-01-2009, 08:42 PM
Trevor's Avatar
Trevor Trevor is offline
This will probably overcome the fault. But as I have advised many times, will not fix it. N.B. Refer last page, current post, "Lets talk about this annoying hot start problem".
Trevor, New Zealand.
Old 08-01-2009, 10:34 PM
kwren's Avatar
kwren kwren is offline
The Bosch relay has started my car several thousands of times without fail since I did it! There is no other known solution to this problem.
If this is not a "fix" it is danged close!
Cheers, Trevor
Keith
Old 08-01-2009, 10:36 PM
kwren's Avatar
However...
We pray a lot!
Keith
Old 08-02-2009, 12:02 AM
Trevor's Avatar
Originally Posted by kwren View Post
However...
We pray a lot!
Keith
That the existing fault will not develop further, on a cold and rainy night.
Old 08-02-2009, 06:14 PM
Well then, lets go ahead and recomend a full harness replacement of everything related to the starting system to get it done your way. That won't cost thousands of dollars or anything.
Old 08-02-2009, 06:33 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
How about we recommends that da guy cleans both ends of his main starter cable, then if that doesnt work, pull the starter and bench test it.
Old 08-03-2009, 02:57 PM
Trevor's Avatar
Best to take the logical approach and properly check for voltage drop, all along the tenuous electrical path involved, which includes many sets of interlocking control contacts.
Old 08-02-2009, 11:37 PM
kwren's Avatar
Sorry, a full harness replacement will not fix the fault, and finding everything related to the starting circuit might be an impossible task.
Keith
Old 08-03-2009, 05:46 AM
dcarrb dcarrb is offline
With so many cars apparently having this trouble one might think that someone would have isolated the culprit by now.
dcb
