Autoseatbelts Fixed!
I know there's alot of people out there that have the common, "gotta open the door before you turn the car off, or the seatbelts wont retract problem." And while searching have found very little advise on how to fix it. Well fixed mine after 2 months of tinkering, and the solution was.................drum role please.............a loose connection!
There's a 4 wire conenction directly below the seatbelt motor. Even though there's a "lock tab" to securely hold the connection together, there's a lot of play in it. The instant I pushed the two conenctions together, the seatbelts fired. Doesn't seem like they have been messed with, just looks like the connections were a poor engineering build. Zip Tied the connections together and the seatbelts have been working perfectly for a week now. NOW GO FIX YOUR SEATBELTS |
I will go try this right now. If it fixes it, I will bow to the east for this great suggestion. That is probably the only thing that I have not tried. It worked like yours, but now it will not go back. It will only go forward. I will let you know how it turns out. Thanks
Yee-ha.
I'll be interested to hear if this fixes it for earl!!
Mike |
bow to the four points
Hey,
Now my Auto Belts did this a time or 3.. Kinda funny trying to get out when not expecting it. then all would retunr to normal. it's comes and goes... I think I've now just gotten so use to opening before I turn the ignition I dunno if it still has an issue or not. BUT thank you very much for this suggestion. Now Back in the old days of Yahoo there was mention of something like electrical contact grease called Cromlin. it's not really a grease but more of a eletrical stabilant. VW has such a product for Audi and VW's. It's not cheap and no one knows what the name is.. I've heard too many swear by it and it's gota make ya wonder why Audi has something VERY similiar to it.. Protects contacts and enhances connection so they claimed. I've searched and searched and never found it.. but I know it exist... SVX1999 |
Hmm, I wonder if that stuff would help us with dim headlights?
Hey 96svxer, could you include a pic of the "4 wire conenction directly below the seatbelt motor"? I'm really anxious to fix mine. I've been riding around for the last month without a belt across my chest! :-P
The motor is not in the door right? It's located under the panel, below the rear window correct? SO, if that's right, I have to take out my rear seat - top and bottom?
'92 Touring Ebony |
I dont have a pic but you dont need one, really easy to find. I just removed my bottom seat, left the top on, You have to recline it to get at one screw though I believe. Yeah the seatbelt motor is located right below the rear window. You'll see the seatbelt motor at the bottom near the door, cant miss it, if you do slap yourself. And there is a large four pin connection, the only one, feeding the motor.
Just an update though. My wife borrowed the car and magically the seatbelts seem to be an the frits again. It worked perfect for me for a few weeks, now they are working most of the time, wich is still better than none-of the time before. So Not sure if this is a permanent fix or not? Possibly another conenction loose? I will be looking at it again this weekend. It's easy so it's worth a try I guess. |
Awright, I removed the rear seat and checked out the connector. I even tied a wire tie around it for more "snug" factor. Unfortunately this didn't cure my seat belt issue. Furthermore, I ran a self test with the diagnostic plug with pin #8 and that produced zilch. There isn't any fault codes stored in the memory for the belts.
Back to the drawing board for me! Ali '92 SVX
Sorry to hear that. Yeah my seabelts worked great for about two weeks, and they are on the fritz again. Who knows. So I completly tore apart me door and got out my old multi-meter and starting measuring voltages and resistance (cant let those 4 years of college go to waste). Again, I wasn't getting any seat belt error codes either. I drew out a complete pin out of all pins/connection/voltages/resistances. Basically what was happening, long story short is my seatblet motor was'nt getting any voltage, when I applied 12 volts directly to the motor is fired and ran fine. SO that leaves up with either a bad limit switch (even though I didn't have a code) or a bad computer. I measure the resistance over the rear limit switch and it had some very funny readings, so I'm guessing the switch was going. Keeping in mind that my seatbelts would fire sometime, and not others. I'm ordering a new one from Kervin subaru, I'll let you know if it cures the problem. If you want I could e-mail all the measurments I took. Maybe it will help you out
Are there any relays that can be experiencing bad contacts in this circuit? After so many cycles, I wonder if one of the relays simply need replacement. I'll need to refer to the electronics manual to see what's up. Do let me know of your progress.
Thanks. Ali
That was my first thought, somebody told me of two relays located below the rear window that control the seatbelts, I found none. Unless these relays are located in a remote location there are none, but why would you need a relay on 12VDC? You probably dont. Limit switches dont require any current. And the motor is driven off it's own wire bundle, not sure if it requires a relay, doubt it though.
Need no relays?
-Pavan. |
hello people,
im having a problem with my seat belt were it would get stuck going forward when i open the door....im able to tap it on the bottom and it retracts forward like normal but recently my seat belt has been spewing wire noodles all on my back driver side window leaving it all grease when i open the door...when i close the door the track wire goes back in. Anyone having problem with the auto seat belt getting stuck when you open the door were you have to tap it in order for it to retract forward? |
