Sway Bar End Links
I took my car to midas to have the alignment done and they said my front passenger Front Swaybar End has some play in it. Can i get some help for what part it is and whats the part # is so i can order a new one. They want $178 + Labor to do it.
1) FRONT WHEEL BEARING 2) KNUCKLE 3) LOWER CONTROL ARM 4) LOWER BALL JOINT 5) STRUT 6) STRUT MOUNT 7) COIL SPRING 8) STABILIZER BAR 9) BUSHINGS 10) BRACKET 11) LATERAL ROD 12) LEVER 13) LINK 14) CROSSMEMBER 01 $622.26 Sub frame assy(front) 02 $269.71 Lower arm sub assembly right hand 03 $269.71 Lower arm sub assembly left hand 04 $63.12 Ball joint complete 05 $1.93 Flg bolt socket m12 06 $1.55 Self lock nut 07 $4.39 Flange bolt arm fm14 08 $80.04 Stabilizer front d18 09 $33.34 Lever stab front 10 $6.27 Bush stab in front 18 11 $5.35 Clamp stab front 12 $0.80 Flg bolt 13 $2.91 Self lock nut 14 $46.24 Link complete stab front 15 $1.37 Bolt&wash assembly 16 $8.15 Stpr flt bush front 17 $10.96 Spt sub frame front 18 $32.99 Spt sub frame rear 19 $3.25 Flg bolt sub fr 20 $1.71 Flg bolt(stopper)m12 21 $2.49 Bolt stud m10 22 $30.85 Performance rod 23 $1.04 Flange bolt Or do i just need to tighten a bolt? How can i check this to make sure i don't waste my money. I plan on replacing it myself then taking it somewhere else to have the alignment done. many thanks -mike |
My guess is they are talking about 13 on the top diagram, 14 on the bottom.
If you pull a wheel you can readily inspect these links. There is a joint on both ends, check for play. You should be able to twist it, but not shake it. Another possability is that the bushings are shot. They are 9 top/ 10 bottom. Chike did a how to on replacing them with aftermarket.
Upon inspection the end link is a little bent near the top where it mounts to the strut. I had to take a straight edge to it to see the bend. Is this supposed to be like this or should the end link be straight as an arrow? As for midas saying there is play in it... thats BS.
Here is the link to Chiketkd Prothane Bushings Install http://www.subaru-svx.net/forum/show...232#post282232 Last edited by mikeytown2; 07-11-2006 at 10:26 PM. |
It's supposed to be straight. I would remove the top nut and inspect the hole the link goes through. Mine was elongated and would cause free play. All we did was cut a chunk of washer to fill the gap. Been like that ever since
I inspected the other side and that also has a very slight bend in it near the top of the end link. both sides have no play, so i think midas was looking to make a buck off of me. Oh well.
NW alignment shops http://www.subaru-svx.net/forum/show...alignment+shop |
I replaced mine with links from a late model Cougar (the small one.) The studs point the same direction but since I put them on almost a year ago they haven't been a problem. My cost was $16ea so figure less than $30ea retail.
Plus, they're shiny aluminum! Oooooooo If I recall correctly, the originals had a slight tweak on one end.
