SVXBot
Go Back   The Subaru SVX World Network > SVX Main Forums > Reading Meet
Old 05-10-2019, 01:42 PM
Pristine Green Polo Machine
Exclamation Reading 19 WEATHER
FIRST GLIMPSE
I will continue to monitor and update the forecast frequently over the next week.
File Type: jpeg 954AC29F-090A-4933-AB46-9853E4B1936B.jpeg (45.4 KB, 182 views)
File Type: jpeg 3DB74829-D015-499B-967C-D14760DAA3B8.jpeg (13.6 KB, 180 views)
File Type: jpeg F7C69012-5992-4AB3-9171-FB4E1C6D20D7.jpeg (42.6 KB, 173 views)
1996 Polo Green LSi #216...137,900 miles...
JFICX8659TH100216JF1CX8659TH100216........Mfg. Date: 11/1995.........In-Service Date: January 2, 1997
HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, Raceconcepts dimpled/slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler.
R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a COW March 4, 2016
2014 Hyundai Elantra Limited ...119,000 miles. Actually quieter and smoother than the SVX
Old 05-10-2019, 03:56 PM
wdb wdb is offline
dances with roads
Re: Reading 19 WEATHER
Well I sure hope so! We could use some dry weather. We haven't had much in the way of dry weather in about a year! Seriously.
2007 BMW 328i Cabriolet
2007 BMW Z4 M Coupe
2012 Tacoma 4wd v6 Access Cab
Old 05-12-2019, 10:32 AM
Huskymaniac's Avatar
Uses the ignore feature
I think I may take the drive down this year. Maybe this crap weather is behind us. Any chance Tom might be there?
Tony
1996 Subaru SVX LSi, 153,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads
2005 Acura RL, 152,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil
2009 Toyota Venza, 100,XXX, Mobil 1 5W30 High Mileage Oil
Old 05-13-2019, 07:07 PM
File Type: jpeg C3C6DF35-346D-4CCB-A620-C6B6352DA464.jpeg (78.7 KB, 149 views)
Old 05-14-2019, 10:40 AM
ALL OVER THE PLACE
File Type: jpeg 97ADA0EE-175C-48F4-9833-E9AB05D316CE.jpeg (119.4 KB, 139 views)
Old 05-14-2019, 04:03 PM
wdb wdb is offline
dances with roads
I may have to bring the cabrio.
2007 BMW Z4 M Coupe
Old 05-14-2019, 04:11 PM
LATEST FORECASTS
Accuweather.com
Weather.com
Weatherbug.com
Yahoo!
Old 05-15-2019, 01:37 PM
National Weather Service NOAA
File Type: jpeg 12FC22CB-D117-4AF3-AA3A-332DB4767A64.jpeg (191.7 KB, 111 views)
Old 05-16-2019, 08:55 AM
24 hours away
File Type: jpeg 566868D5-A00C-4866-B259-D92250BCFA85.jpeg (112.2 KB, 103 views)
File Type: jpeg 30045C1F-6761-450A-AA71-03FFC65DD9C6.jpeg (60.3 KB, 103 views)
File Type: jpeg 6577B00D-DEBE-41AB-A2A5-40FDD5A36121.jpeg (74.5 KB, 103 views)
Old 05-17-2019, 08:34 PM
A PERFECT READING WEEKEND!
File Type: jpeg 433ACE60-01C6-4347-A0A8-A44626C2E37C.jpeg (258.8 KB, 92 views)
Rate This Thread:
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
