Old 01-16-2004, 10:46 PM
jamesy jamesy is offline
planing replace timing belt !
I have all the info. for replacing the timing belt, but im not sure what i have to pay attention on.
did someone here have done this replacement before?
Could anyone give me some advises, thanks.
James
Old 01-17-2004, 05:55 PM
How many items are you planning on changing while you're in there?
Old 01-17-2004, 07:54 PM
CDG's Avatar
CDG CDG is offline
No front plate on My SVX
Send a message via MSN to CDG
Exactly, THERE ARE 2 TIMING BELTS, thats the first thing.
Secondly, taking apart the AC may cause you issues later. Avoid it if posible.
Inspect the gears very carefully.
replace ALL the seals. Do the water pump too. And I think theres another consumable you should replace while your in there, but ask around.
Be careful, don't drop any parts inside.
Thats all the wisdom I have, as I have not personally done an SVX.
Chris G
92 Pearlie, sold @ ~209k miles. Now owned by Tim.
Current Ride, 1985 Honda Aero 80, stock 3024 klms
Old 01-17-2004, 10:07 PM
boundsie
Two timing belts???? I must have missed one when I was in there. While you are in there, change your cam seals, main seal and water pump. At least that's what I was told so I did it. Water pump looked fine at 100K but the seals were shot.
Old 01-17-2004, 10:58 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
I thought a writeup was around here...
My foggy memory says that someone documented this procedure pretty well at one time.
However, it is not in the how-to folder. If anyone knows where it is, Hook us up dawg!
'20 Honda Ridgeline
http://www.x35design.com
Old 01-18-2004, 01:15 AM
I thought it was in the How-To Locker as well. When I went there to link to it, I found that it was not there. I will get it in there as soon as we find it.
Old 01-18-2004, 08:28 AM
Green1995SVX
There is one timing belt.
mike
Old 01-18-2004, 11:35 AM
CDG's Avatar
CDG CDG is offline
One for both heads?
OK, I'm wrong, I thought there were 2.
Sry.
Chris G
Old 01-18-2004, 01:25 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
yup, only one due to the helical gears driving the intake valves...although there would still only be one so everything is timed right.....
phil
~Phil
Old 01-18-2004, 07:31 PM
GreenMarine's Avatar
From POST-***** to LURKER
Re: I thought a writeup was around here...
Was it Huck??? I think that he told me that he was doing something like this last October... Check with him...
Old 01-18-2004, 09:47 PM
This picture should show you how the belt works.
Old 01-18-2004, 10:16 PM
SubaSteevo's Avatar
No longer blue member
Re: Re: I thought a writeup was around here...
Nope, Ryan MacDonald did it www.ryanmacdonald.com
Edit: Site is under construction
-Steve
01' MSM Lexus IS300
Old 01-19-2004, 07:05 PM
CDG's Avatar
CDG CDG is offline
Hey look, only one belt. wow.
When I printed this pic from who knows where it was a little blurry, so it looked like 2 belts to me.
It looks pretty long, yikes.
Chris G
Old 01-20-2004, 07:31 PM
nnjsvx
I believe the other consumable part is the Belt Tensioner. Most mechanics I have spoken with say they don't usually replace it. My take is it is a wear part and with everything open and 90 % of the labor done why not change it too.
----- Jerry
Old 01-21-2004, 11:23 AM
svx_commuter's Avatar
The belt tensioner came up in discussion the last time. Most of us have just been reusing the tension. Now it has been suggested that this "device" wears and should be replaced. Otherwise the engine will start to sound like there is a bad rod bearing or something when it's just the T-belt/tensioner doing something that makes the noise.
I will not know for sure until I change my tensioner the next time.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
