Old 05-14-2006, 02:02 PM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
Unhappy Help!...Brake lights don't work
So, my rear lights are always on...the lights that are supposed to come on with your headlights. In addition, when I hit the brake, they do not change intensity. This is post 5MT swap. Did I forget to reconnect something? Help is greatly appreciated as I would like to wrap up this 5MT swap. Thanks!
Mat
Old 05-15-2006, 12:23 PM
You didn't do something silly like hit the parking light button did you?
Old 05-15-2006, 02:12 PM
intelisevil's Avatar
<<<Alcyone
Brake lights would still come on . . .
Is there an adjustment for the switch on the brake assembly? I know some older vehicles suffered from this malady. Did you forget to re-plug a connection after installing the pedal assembly?
Good Luck,
Dan
Old 05-15-2006, 02:18 PM
SVX10's Avatar
Thanks
Hey fellas. Thanks for the input. Not sure exactly what the problem was, but I got rid of it simply by removing the brake light switch and re-installing it. All is well now.
Mat
Old 05-15-2006, 03:19 PM
Speedklix's Avatar
Locker Link Solution
Mat
It was probably broken in the swap. It is easy to brake em. Keep an extra on hand. I've broken three of them total in the past.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 05-15-2006, 06:11 PM
SVX10's Avatar
Doubtful...I used the same one when I put it back in I was completely baffled. Whatever...it works now
Old 05-16-2006, 08:33 AM
<<<Alcyone
Maybe a little bit too much corrosion on the contacts, when you removed/reinstalled it you disrupted just enough of it for those little electrons to be able to pass over.
Glad to hear it was this simple!
Dan
