Old 04-08-2006, 12:42 AM
Dessertrunner's Avatar
Have you had a engine fail completely.
Just had a thought was wondering if many of you have replaced engines and what was the reason that the old one died. Might give me a ideas as to what to look for.
Tony
Old 04-08-2006, 06:11 AM
Crusader's Avatar
Crusader Crusader is offline
$13000 and counting...
Send a message via AIM to Crusader Send a message via MSN to Crusader Send a message via Yahoo to Crusader
I had mine rebuit from Colorado Component Rebuilders. Before I sent it in I didn't know what was wrong with it, only that it was knocking bad. Turns out that somehow the oil disappeared (??? still don't know how or why ???) and spun a main bearing.
Old 04-08-2006, 02:55 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Mine is knocking pretty bad when cold right now and I suspect a rod bearing. We''l find out when it dies.
Old 04-08-2006, 03:43 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
if its knocking when its cold and not when it warms up im sure its just skirt slap.
phil
~Phil
Old 04-08-2006, 04:07 PM
hey phil, could you explain "skirt slap"?
Old 04-08-2006, 06:37 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Tony
What happened Tony? Did your engine blow up?
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 04-08-2006, 07:22 PM
SomethingElse's Avatar
word words wording
Isnt that when you lift a girls skirt and...oh wait wrong thread I think it means your cylnders are wearing and probably need to be bored out. Mine car does it just on startup till the oil pressure builds.
Eric
Old 04-09-2006, 12:54 AM
No my engine is okay its just that I can hear a slight knock inthe front but it might be something as it is not always there. I have 320,000 k on it and it still purrs like a baby so I needed to ask the question how these engine end up going to heaven. My bet is most die from radiator, hoses or short oil and not age. Oh yer and thermostate which I think would be number 1. So lets see if any one has one that died from old age.
Tony
Old 04-09-2006, 03:52 PM
Myetball's Avatar
Myetball Myetball is offline
Mr. Inappropriate
I don't recall reading any stories of an EG33 death from natural causes...i.e., high mileage issues. Sure NO2 and overboost can kill it.
Knocking in high mileage engines is usually either excessive clearance between the pistons and cylinder wall (piston/skirt slap) or worn rod bearings. Either way, it's not cheap to fix.
The most expensive part of the EG33 to rebuild is the shortblock. I think main/rod bearings cost over $500 for a complete set. Stock pistons are about $61 each and a set of rings will run almost $270. A full engines gasket/seal kit is about $240.
Add it all up with the cost of machine shop work and it's almost more economical to buy a new shortblock.
Old 04-09-2006, 04:36 PM
immortal_suby's Avatar
Thread Killah
Head gasket went on mine at 215,000 miles.
Other than that she sounded great - no knocking or smoke.
Locker Link
2015 BRZ Limited 6MT
Old 04-10-2006, 09:36 AM
stallion stallion is offline
just so I can somewhat diagnose the condition of my engine, how does this 'knocking' you guys are describing sound like? Is it only heard in idle? How loud is it?
Old 04-10-2006, 09:45 AM
Budfreak's Avatar
Banned
Well, Mine is pretty damn loud. I can hear it just fine inside the car with all windows up and so on. Mine started as a barely noticeable little tapping(The third day I owned it) and over the past year and a half it has grown from me having to open the door and stick my head out to hear it, To being so loud now I can hear it from like 100FT. away. It's so loud That I'm almost to embarassed to let it warm up before I take off because everybody can hear it knocking. I still say rod bearings due to the fact of how it has grown over time and the fact it got MUCH worse after 4.44's were installed. You can still hear it when warmed up, But you have to listen for it and it's just like a tap.......taptap............taptaptap.........tap. ....tap..... When fully warmed up.
Old 04-10-2006, 09:56 AM
Is there any maintenance tips to prevent this from happening?? (Changing gasket etc that kinda thing..) Sorry I'm a total noob but I dont want to end up with a f'd up SVX!!!
Old 04-10-2006, 02:35 PM
The original engine lasted 70xxx and then I believe threw a rod havent torn it down yet. THen the new to me used engine only lasted about 4000 miles beofore the rod bearings finally crapped out on me. SO mine are not the best examples but thats my story. Now i work at subaru so now i can atleast get good prices on parts for the engine rebuild.
Old 04-10-2006, 05:45 PM
spinn360's Avatar
spinn360 spinn360 is offline
a$$ out of u and me
I would assume that most SVX's live's end for there owners with the tranny rather then the engine. But you know what happens when someone assumes.
1989 Subaru XT6 130k
1992 Subaru SVX 120k
1993 Ford Probe 30mpg 213k
1989 Subaru XT6 150k
All good and running
