Timing Belt Change Interval
When is the timing belt supposed to be changed in an SVX. For example, 6 years or 80k miles whichever comes first. Also, what other parts do you replace when doing the belt. Water Pump, cam seals, crank seals, etc. What belt should one use, original subaru, Napa, etc.
Here is the link to the maintenance schedule. This should answer your questions on intervals.
Is the maintenance interval Subaru recommends for engine oil changes truly 7,500 miles?
Hmm, it says to check the wheelbearing lubricant at 60,000 miles.
Is that were we could be going wrong?
Tim 92 Liquid Silver SVX 5MT 2009 BMW Z4 (Gone) 2012 Camry V6 SE |
Read you're manual there boy (or sorry forgot you were from the sticks... Have it read to ya) It goes something like this 7500 miles for the oil change unless you drive 1. Short distances, 2. In congested traffic or through traffic lights, 3. On dusty roads. Which unless you live in the midwest sticks and only drive on the highway I think that pretty much covers everybody here then you should change it every 3750. I know this has been Subaru's recommendation at least through the EA-81 engine series (early 80s) and probably even earlier.
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
Don't shoot the messenger - I only posted the link!!!!
Chike You need to change your oil more often so that you can oil the road out in front of your house so it isn't as dusty.
Thread Tools | |
Display Modes | |
