Old 05-02-2010, 06:55 PM
SVX33 SVX33 is offline
Re: reprograming a remote keyless
I just went through this with the same problems, eventually realizing you need to be quick about it all. The only difference is I get no parking light flashes. In fact my lights have never flashed when using the remote, just the horn toots and interior lights come on. Can something be amiss?
Old 05-03-2010, 11:29 PM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
Sounds like a problem with the parking light relay inside the module. Unplug the module from the car, carefully open the cover, and look at the relay -- it's very large and open.
You can look at the contacts and see if you can move the armature manually. You can even plug the module back into the car and watch whether it moves at all. Or break out a voltmeter to do some real testing.
Just be careful handing the security module -- it contains static-sensitive components.
David C.
1996 Laguna Blue Pearl SVX L AWD
See my home page for SVX radio install/removal instructions and wiring harnesses
Old 05-05-2010, 09:24 AM
Thanks, after a brief thread search, looks like "all" I have to do is get the glove box out now!
Old 05-08-2010, 03:02 PM
Ok, so I got the module out and the relay doesn't operate. Is there anyone who knows of someone that repairs these?
