Engine stuttering at low rpm's
I recently purchased a 92 SVX with a 5 speed manual swap. When I drive the car and begin to start in 1st gear and accelerate from 1000 rpm's up to around 3000 rpm's the engine feels to stutter, such that it's like it's not getting the proper fuel ratio, but once it gets around 3k or higher it runs smoother. This tends to do it in 1st and 2nd gear mainly, and sometimes in 3rd gear depending upon where I drive and how I shift it.
I am not sure why it would be doing this. Any help and/or info would be greatly appreciated. Thanks in advance. |
Re: Engine stuttering at low rpm's
Trans mounts?
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
I guess that could be a possibility, I haven't had the chance to look everything over.
Maybe start with checking for error codes? Maybe change the plugs.
That's the first thing I'm going to do. I am hoping that solves the problem, will find out next weekend or the following weekend when I can get the time to replace them.
does it do it when its out of gear?
No, it's only when I have the transmission engaged and am accelerating.
Propbably an igniter coil on its way out.
Hmm I haven't thought about that, how difficult is that to check and replace as needed?
06 Ford F150 Crew 4x4 142K+ miles 05 Volvo XC90 163K+ miles 02 Toyota Camry 170k+ miles |
durring accelration... but only in first gear... or in all gears?
During acceleration in at least 1st and 2nd from 1000 to 3000 rpms. When I shift to third gear sometimes it does it when I'm below 3000 rpms.
If that's the case, the problem will progress to misfiring at idle and while in park. At that point it should be more easlily diagnosed by disconnecting ignitor coils one at a time and starting the engine. If the shaking gets worse, that's probably not the one. If the shaking gets better, it's probably the one on the opposite side of the engine in the same position. The front ignitor coils are easliy disconnected. The back ones not so easy. Start with the front ones.
I will check everything out this weekend when I get home from being away at work this week. Thanks for all the info.
Thread Tools | |
Display Modes | |
