Old 04-22-2006, 04:37 AM
nutshell's Avatar
nutshell nutshell is offline
Send a message via AIM to nutshell Send a message via MSN to nutshell Send a message via Yahoo to nutshell Send a message via Skype™ to nutshell
Strange drive train noise on acceleration
Recently I posted on the epic of repairing the 4WS on my newly acquired 91SVX. However, with that corrected, I now have a drivetrain problem.
At a moderate speed, 35-40 mph, and up, I get a high pitched droning noise that appears to be load dependant. That is; if I throttle off the sound disappears, and returns when the power is applied. On a very light throttle it sounds (rattles briefly) like a bad or collapsing bearing someplace.
At first I thought it may be the intermediate hanger bearing on the driveshaft, but now I am not so sure. The noise is very mechanical and overrides usual engine/gearbox chatter, which sounds totally normal.
It seems to be getting worse.
Any suggestions?
FYI the gearbox was apparently reconditioned only a matter of months ago.
Ian
Old 04-22-2006, 06:28 AM
intelisevil's Avatar
<<<Alcyone
I had something similar except that my noise occured on decel, went away on accel. A spot of exhaust shielding was scraping against the driveshaft as the engine torqued around. A bit of prying when the car was up on a lift took care of my problem.
Hopefully yours will be as simple to find and fix.
Dan
Old 04-22-2006, 03:54 PM
nutshell's Avatar
Dan
Thanks...problem solved...it looks like it may be the heat exchanger on top of the rear right hand muffler. Blasted thing.
I'll get it in to my friendly muffler shop next week for a fix.
Old 04-22-2006, 07:13 PM
-JJ-'s Avatar
-JJ- -JJ- is offline
Endangered Species
Send a message via MSN to -JJ-
Check this, i hope it is something simple aswel
all the best
1992 Pearl / Black SVX
removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads
Old 07-20-2006, 06:14 AM
nutshell's Avatar
Talking You won't believe this!
WOW..this has taken some time to fix...but finally done and everything working as Subaru originally intended.
It is an unbelievable tale of bad workmanship tho...
The noise was not any body parts rubbing or rattling.
Apparently when the agent (Winger Subaru) repaired the transmission for the previous owner, they sent the unit out to have the work done by a local auto-trans 'specialist'.
I located another transmission specialist and after a run he diagnosed the front trans-axle pinion bearing, so I gave him the job of fixing it.
However, after they had removed the transmission he called me and asked me to call by the shop where they had the trans-axle laid out on a bench.
Believe it or not, there was less than one egg-cup of diff fluid left in the axle housing!!
Both pinion AND crown wheel had run so red-hot they had actually peeled the metal up and off of the facing teeth on both parts!!
Seems that when the first guys did the work they had neglected to put in a thirty cent O-ring that seals the face of the pinion bearing housing to the gearbox, so that over time all the diff oil had migrated FROM the axle INTO the gearbox, leaving the trans-axle dry as a bone!!!
No wonder it was complaining! And just imagine what that heavy-duty axle oil had done to the rest of the transmission when it mixed with the light-weight auto-trans fluid!!!
After some hasty calls and much, much, much conversation Winger agreed that the work had been incorrectly done...and eventually (three weeks later) I was presented with the car...back in good working order.
Do not ask me how much work had to be done to get it repaired (or how much it eventually cost someone), but it did need a complete replacement crown wheel and pinion, and a complete transmission rebuild, including the rear clutch pack.
To cut a long story short, the work cost ME just two replacement rear gearbox mount ....no more than that.
I have to give credit to Winger Subaru in Auckland. When the chips were down, as a Subaru agent they did the right thing by the SVX.
And...as a result..the car now drives as it was intended....perfectly.
4WS is a challenge for sure...but as the days and weeks go by I believe I am mastering the art of the ability to turn on a dime. It truly is a great design and makes what is undoubtedly one of the best vehicles ever made into something that is just unbelievable.
I just wonder why Subaru never continued with 4WS?
Ian
Old 07-20-2006, 09:06 AM
mbtoloczko's Avatar
sans SVX
Ian
Glad you got your car fixed, and got it done without having to shell out big bucks.
Quite a few automakers tinkered with 4WS and none adopted it permanently. I'd venture to guess that there's not enough advantage to 4WS for the added complexity and cost.
Mychailo
Visit my locker
Old 07-20-2006, 07:58 PM
oab_au oab_au is offline
Yes I think the complexity and cost, was the killer. Especially when they could get enough passive rear steering, from the short trailing link.
One Arm Bloke.
Tell it like it is!
Old 07-20-2006, 09:35 PM
Trevor's Avatar
Trevor Trevor is offline
How does this suggested alternative arrangement provide actual rear wheel steering, but does not induce one wheel/side bump steer ?
Trevor, New Zealand.
