Old 07-25-2016, 05:04 PM
Jvan Jvan is offline
question about rear vented rotors
I was reading some old threads concerning brake upgrades and discovered that the SVX's in the UK/NZ and maybe other markets came w/ vented rear rotors. Has anyone made a swap of these vented rear rotors into our USDM SVX's ? The ticker rotors would require wider calipers and maybe a different proportioning meter but would certainly help braking fade. Since our calipers are from the Legacy, a swap would seem possible.
Old 08-20-2016, 12:21 PM
Re: question about rear vented rotors
i put the rear vented/slotted rotors from disc brake Australia on mine. was not worth the time/effort involved. it took three attempts and six months to get the right parts and it wasn't a noticeable difference. the front brakes are the weakest point on the svx, the rears seem adequate.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 08-20-2016, 04:14 PM
Kind of sorry to hear that it's not a simple swap. Since it is OEM in some markets, I thought it might just be a matter of wider calipers and different brackets.
Old 08-21-2016, 02:06 PM
BelegUS BelegUS is offline
European SVX owner here: those vented rotors are PITA to get. I actually wonder if going US-spec rear brakes wouldn't be a better option...
Old 08-23-2016, 06:33 AM
Chucksta Chucksta is offline
Slotted / vented / cross drilled etc, are cheap enough on Ebay..
http://www.ebay.ca/itm/FULL-KIT-BLAC...BXpXfn&vxp=mtr
No, they're not Brembo.. but they'll work just fine for anything up to aggressive street driving.
I've gotten on mine HARD from over 200 KPH, .. they didn't warp :-)
Neither did the fronts, same kind.
That being said, I don't think that they'd hold up to Autocross type driving, but for agressive street driving, they're fine, and I love the sound..
Old 08-23-2016, 02:14 PM
U mean these
I had a caliper seize up so bad I had smoke coming out the wheel well when I parked .. Rotor is fine.
Old 08-24-2016, 10:33 AM
scoobymal's Avatar
scoobymal scoobymal is offline
Smile Re: question about rear vented rotors
Hi, you sure that the rears are vented? I thought only UK/JDM and European cars got them.. I've been looking in the UK for some, not much choice
Old 08-26-2016, 04:38 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
NZ new did not come with vented rears - but there are quite a few JDM imports here with vented rears.
If you (in the USA) decide to "upgrade" to vented ones then you will also need different calipers and pads - which you will find hard to get hold of in the future....
Check out this site which I have used to get a few parts from in Japan - quite a bit cheaper than local in NZ.
http://www.jauce.com/search/Subaru+SVX
have fun.....
Old 09-06-2016, 03:27 PM
Since our calipers are from the Legacy, I thought that getting rear vented rotors/calipers/brackets wouldn't be such an issue.
Old 09-08-2016, 12:49 AM
SURTEESS's Avatar
I also remember someone mentioning that they are the same as Nissan Pathfinder ?.
Old 09-08-2016, 08:34 AM
SVX_MY_BABY's Avatar
The Pads are according to the x-ref materials.
Peter
Old 10-01-2016, 06:10 PM
Are we saying that the rotors/caliper are from the Pathfinder since the pads are from that vehicle? Many cars/crossovers/etc. can use the same pads but the remaining brake parts are different.
