ABS craziness
okay, just had the ABS module replaced, a $750 item, and the ABS light came back on and the ABS doesn't work, but get this-sometimes the ABS light goes out and the ABS starts working, even when stopped! yup, it starts clicking on the brake pedal and I'm not even moving!
There is a "how to" on checking ABS codes.
i've had tomssvx and sicksubie check for codes, it was fixed this morning, then the light started going on and off, see below
Sorry, I can't help.
Mine wasn't working when I bought the car. I never really saw the need to get it working. With decent tires and proper driving, I was never really a fan of ABS. ^^^^Post # 3,000
Dave - 03 Baja - 92 SVX - 86 Brat - 08 OB 3.0 Last edited by Hocrest; 01-17-2008 at 09:09 PM. Reason: Celebration |
bLAh
Check the yellow connector near the kick panel. I had the same symptoms. If I moved the connector, the ABS light would go ON and OFF. I had a bad connection, so I held it together tightly with a wire tie and all is well.
Sorry my bad! This was the airbag not the ABS! Ignore this comment. Last edited by dannmarr; 05-28-2009 at 09:23 AM. |
