Old 12-27-2019, 12:04 AM
ParkerC137 ParkerC137 is offline
Unhappy Help Needed
This post is for my dad as he is the owner of the SVX in question. He hasn't been able to get his started since he replaced the fuel pump almost two months ago. His is a 1995 and it'll crank slowly but not turn over. If anyone can give him some advice or even a helping hand it would be greatly appreciated. We're located in NEPA around the Wilkes Barre Area.
Old 12-27-2019, 12:16 AM
irox irox is offline
Re: Help Needed
Was the car running before the fuel pump was replaced?
I would guess the car had some problem, and the fuel pump was replaced in hope it would fix the problem. But since it's not ran since the new fuel pump, I'm guessing it didn't fix the problem.
I've replaced my fuel pump to fix a problem, and it turned out to be a completely different problem. In my case it turned out to be the wiring to the MAF connector, but in your case you could see those symptoms with a failing MAF.
Since the fuel pump was changed, was the fuel pressure checked?
Also, did your dad check for any error codes?
Even if the check engine light isn't on, the computer could be storing error codes that could help identify the problem.
Good luck!
Ian.
Old 12-27-2019, 12:47 AM
Re: Help Needed
Yes it was running before he changed the fuel pump. He also fixed some wireing problems along the lines for the fuel pump.
Old 12-27-2019, 03:45 AM
Re: Help Needed
When you turn the key on, just before the start position, can you hear the fuel pump run?
Old 12-27-2019, 04:15 AM
SoCoNoHa's Avatar
SoCoNoHa SoCoNoHa is offline
H6 Fanatic
Re: Help Needed
Ya what he said. The pump should prime itself for a second or two when the key is turned to ignition. That'll confirm the wiring and new pump are good to go. Also, perhaps try to find some photos of the fuel lines back there to ensure they were reinstalled correctly, I imagine the FPR wouldn't work very well in reverse.
Did it always crank slowly? Sounds like a potential new wiring issue if it previously cranked quicker. Bad ground or such?
1992 SVX LS-L : King of the Stable
LGT 5MT, ABS Delete, Short Ram Intake, Custom Exhaust, Drilled/Slotted Rotors
1993 Legacy sedan : winter beater, supposedly.
1994 Legacy wagon : future drift car?
1995 Impreza coupe : EZ30++, daily racecar.
1997 Legacy GT : date night rocket?
2003 WRX : future winter beater
Old 12-30-2019, 07:05 PM
Re: Help Needed
Yes it was cranking slowly!
I'll update him with all of your suggestions.
Thank you,
Old 01-03-2020, 11:44 AM
lsupcar lsupcar is offline
Re: Help Needed
If your issue is still unresolved, check, charge, or replace the battery and/or starter.
