Duty solenoid C replaced, but still have the code
I replaced my duty solenoid c but still get the 16 power light flashes. I pulled the code and get duty solenoid C after resetting everything. I don't have binding but the car feels like it's in full time 4wd. It also rocks back and forth after shutting the engine off from park and clunks very loudly when shifting from D to R on a steep slope. Can someone who's knowledgeable and isn't a smart-ass kid punk please help me out here? I'm stumped.
Re: Duty solenoid C replaced, but still have the code
Your discription does sound like the solenoid is not opening, to keep it in 4WD. If you are getting a code for the C solenoid, then it means that there is a short, or open, in the wiring to the solenoid, or the armature in the solenoid is not responding to the duty cycle signal. As the solenoid is new, we can discount the last one and just look at the first two. The wire to the solenoid may be jamed between the cases, or it was not plugged in when it was fitted. Harvey.
Thanks for this information. Do you know where I should look for a short and where the wire is? Is it hard to get to?
Pull the plug apart and check the Green/Red stripe wire to the box with the meter set on OHMS. You should get a reading of ~12 Ohms if the wire is connected to the solenoid. If it is a high resistance (wire open), the plug inside the box may be apart, or was not plugged in, when the rear of the box was fitted. If you get zero resistance the wire is jammed between the rear case and the box case. You can see the solenoid and the plug to it, on the left bottom of this diag. http://www.subaru-svx.net/photos/files/oab_au/3097.JPG Harvey.
Since you included the smart ass punk comment, I felt compelled to post in here.
Here, have some spiders!
http://i840.photobucket.com/albums/z...93705d9zzz.png |
Thanks |
I see a connector on the left side of the engine bay and a wire that runs down behind the front left axel. Is that the one that goes to the solenoid that you'd like me to check?
