Freewheeling in "D" or "R" at idle
I have to hold the brake when transitioning from one direction to another, or from a stop, on an incline, as the car will roll at idle, forward or backward, as if the gear selector were in neutral. Raise the revs a bit and it'll grab and go.
ATF is clean, clear, and full. No measurable drop in fuel economy (this has been going on for awhile). No unusual delay after shifting from R to D or vice-versa. Good bite in all gears, at any speed. I drove the car 150+ miles Friday, fairly hard, Interstate to curvy, hilly 2-lanes, and the tranny performed flawlessly in every other respect, near as I could tell. I've put over 50,000 miles on this car and believe I'd notice any change in behavior. So this seems a minor issue, but I'd appreciate some opinions as to what's up, and more importantly, if this a foretaste of bad things soon to come. Could it be something as simple as a bad signal from the TPS? Thanks, dcb |
Re: Freewheeling in "D" or "R" at idle
Hi DCB, I recently had a right front axle blow up on my Legacy. I had to have it towed in. When I backed it out into the street and put it in park, it started rolling backwards down the street. The wrecker guy says you don't have park when you have a blown axle. Although this is a little different it seems like it might be in the same ballpark. Take care, BOBB
Thanks, Bobb, but it's definitely not an axle; not a slop-in-the-driveline issue.
Not noticeable at cold idle: This morning I backed out of the garage without touching the gas. Engine braking at speed seems okay, if holding a steady 60 MPH with the cruise control on a downhill grade is any indication. dcb |
Sounds like a TPS issue to me...
Well, I guess it's cool that there's no deluge of oh-man-yer-screwed replies. I've never replaced the TPS in this car so it's probably original. If I decide to get myself a new one for Christmas I'll update.
Thanks, dcb |
Rather than wasting a good Christmas gift on it, usually the stock ones can be adjusted/cleaned.
See how-to documents for further info. Not overly technical, just need some brake cleaner, screwdriver, multi-meter and, of course, patience.
-Craig 94 LSi 5spd Barcelona Red, 14Xk miles. Full custom exhaust (Stebro cat-back, custom rest of the way forward) 8000K HID kit from Tom (SVXfiles), Energy Suspension front sway bar bushings, Non-Droopy visors, Race Concepts C/D + Dimpled Rotors, Axxis Ultimate pads,SS brake lines, Bontrager Works #009 (or something like that), stripped interior. (up next) Full cage, fuel cell, 327 swap |
First, I'm no expert, wish I could tell you what's up
Second, what happens to the rpms when you are in D and downshift into 3? Do you get engine braking, or neutral?
Does the same thing happen from a stop if you select gear 1? Have you recently driven the car with fwd installed?
Thanks for the input, everyone.
My thinking (perhaps overly wishful) on the TPS was that the transmission is not getting a proper signal to "go" at operating temp 'til I bump the revs. I tried cleaning the TPS on my other SVX to no effect. Ultimately, replacing that one cured a gear-hunting, weird-inappropriate-AWD-bias condition. Have not shifted from "D" to "3," nor tested in FWD. Will do. It's not just in drive, also reverse. I first really became aware of this when backing into a parking space on a nose-down incline. At idle, if I don't hold the brake the car will roll forward—selector in "R"—as if in neutral. Waiting for a car to pass before making a left recently, incline reversed, in "D," the car wanted to roll backward. At or above, say, 1000 RPM, all seems good. I drive this car 2-3 times per week at minimum (25+/- mile RT, 2-lane, curvy, rolling terrain) and have noticed no other worrisome behavior. Transmission was alleged to have been recently rebuilt when I bought the car @104,000 miles. My "proof" of this: An e-mail from the salesman. dcb |
No, I've put fifty-something thousand miles on this car. No tranny work excepting normal fluid changes. Came with a "campaign" external filter (which has been replaced once) and I added an aux. cooler.
I'll drive it tomorrow and check engine braking in 3 and starting in 1 on an incline. dcb |
The symptoms appear to indicate that the problem is engine speed related. The TCU relies on a signal from the ECU in this respect, which in turn receives signals from engine speed sensors. The crank angle sensor signal would be the most likely culprit.
These sensors deliver a series of pulses when magnetically activated. It is possible that at low RPM there is insufficient signal being delivered, but this is not a likely scenario. However you have an intermittent fault, and therefore you must suspect the unlikely. Run an engine diagnostic check as per the how too information. You will be looking for code 11 or maybe 13. Unfortunately as the fault is intermittent this check can not be absolutely relied upon, but will be the first line of approach.
