Easiest way to drain gas tank?
Anyone got any ideas on how to drain the gas tank?
1992 SVX LSL Ex wifey has it now pending self destruction 2001 Legacy mods to come 1992 Subaru Legacy 2.2 214k Boob wheels CANT KILL IT |
I took out the fuel sending unit and siphoned it through said hole.
Drill a hole in the bottom
Unless of course you plan on using the tank again, then go with the other thing
Drive it around until you run out of gas?
I had to drain mine after picking up 4.5 gallons of dark-yellow non-flammable "petrol"
I undid the hose that runs from the fuel filter to the injector rail and put it into a 2 Litre lemonade bottle. When you turn on the ignition you get a 10 second burst of fuel through the pipe then it stops. So you just cycle the ignition switch a few times then empty the bottle and start again. It took an hour or so to drain that much "fuel". After draining it I put in a tank of good fuel, but there must have been a little of the bad stuff left because I was getting rough running and codes from the knock sensors. But that went away after a couple of fill ups. Phil.
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II Last edited by b3lha; 08-07-2006 at 02:05 AM. |
use a hose
Hi,
if you want to keep it really easy and do not care wether a little bit of gas is left in the tank use a hose (from Wal Mart) with a little rubber made hand pump (just because you do not want to suck by yourself), place the long end in the tank and the other in a bin/bottle/canister staying on the ground (need to be on lower level than tank). As soon as the hose is filled, a steady flow will result. Be carefull not to overfill your cannister. Good luck! PS: If you put the wrong gas in the tank dilute the remaining amount with the right gas and repeat the procedure instead of running the mixture thru the engine. |
you can't fit a hose down into the tank to get it out. There's a one-way type door in there before it gets into the tank. You could pump the gas out (like the guy above suggested) from the fuel pump door (under the carpet behind the rear sets) Good luck!
Early deceased SVXWN Member July 1986 -- February 2007 Michael - Duct Tape Man 1992 Burgundy SVX LS-L, 138K: Brembo Slotted/Drilled Rotors, B&M Tranny Cooler and Filter, SmallCar Shift Kit 1992 Burgundy SVX LS-L, 123K: DEAD FROM FATAL HAIL DAMAGE, Parting out so PM me if you need something. "It's only after we've lost everything that we're free to do anything" - Fight Club "This is not my life, this is not my home, this is not me. I HATE THIS!" - Static X |
