#31
Re: twin TD04 project
Most systems run the MAF before the turbo anyway so they don't see boost. The problem is then you would have to Y the intake to both turbos unless you can tune the car and run 2 MAFs, 1 for each turbo inlet. Going to a MAP system with the hydra or megasquirt eliminates that issue and allows an air filter to be stuck at each turbo inlet and be done with it.
#33
back in ontario with my svx so now i will be starting my TT svx project.
ordered the gasket rebuild kit for the spare engine, now i need to source pistons and rods for the build
#35
so any news on this?
seems everyone with this low mount twin td04 idea fails or gives up. |
#36
lol since this post my svx water pump went and cracked the housing, got a 2nd svx while i rebuild the laguna, moved across country so i'm a little behind lol
i've talked to a few people and TD04's are still too small even for a TT setup. so since i need to rebuild my engine, i'm going full build from the ground up might run something like twin GT35R's I will document the build once i get around to having spare funds for it.
#37
GT35's?! What kind of power are you shooting for with those?
I've always pictured a pair of GTX28's with V-band housings... Mmmmmm...
#38
twin 35r's cmon. we can get 700HP out of 1. that and there too huge to fit low mount.
2 td04's will comfortably break 400hp atw. good to hear you havent given up though. a 1000hp+ svx would be absolutely epic though if you do fit 35r's |
#39
my goal is to be in the 600 range, twin td04s wont be enough.
i'm gonna get the deck fully closed.
#40
A couple of VF39's will certainly meet your needs.
Even a single TD04 pushed to max will make 280 whp on a 2.5 Suby. That's theoretically 560 whp with twins. |
#41
my choice would be twin vf34 if aiming for 600ish. or 2 GT2860's wit hth e .6 rear housing or similar. though the garretts have a much bigger housing to fit in underneath.
Thread Tools | |
Display Modes | Rate This Thread |
