Old 09-30-2006, 09:43 PM
SVXtacy SVXtacy is offline
Special Starters?
Another question arises. I recieved 4 faulty starters from 4 different manufacturers when my starter gave out. The fourth one finally worked, but after maybe the 2nd or 3rd time of trying to start it, it would just click for a few turns, as if the starter were busted, then start. I had the somewhat iffy factory alarm taken out, but it didn't really help out. Do we HAVE to get our starters from the dealership to get them to work properly? Is there some kind of reset feature that this weird car requires me to do when I change the starter? This is a real pain, and any help would be appreciated.
Old 09-30-2006, 10:11 PM
Trevor's Avatar
Trevor Trevor is offline
There have been quite a few cases reported regarding lack of signal voltage to the actuating solenoid, due to various causes and the subject has become rather confusing. Connect a test lamp, handlamp, or some other lamp which draws a decent amount of current, across the solenoid at the starter. Do not rely on a voltmeter, as this will not show up marginal resistance in the circuit. Operate the ignition switch start signal and check that the bulb comes on good and bright proving adequate voltage. Observe how the solenoid operates, i.e. solidly or otherwise. Check all connections to the starter while you are at it.
Report back with a view towards curing any fault, rather than adding a relay as a stop gap, which will be your last resort. This fault has proven a challenge for some. You will find a search interesting and informative.
Trevor, New Zealand.
