trouble with the window switch
Hi,
since a few days I am facing a wired problem: The driver's side window switch for the passenger side front window works only one way (I can open the window but cannot close it using this switch). Fortunately I am still able to fully operate this window with the passenger's side switch. Now I wonder wether I am facing a faulty switch only or trouble somewere in the electronic and how I could solve the problem. Thanks! Marcus |
I had the exact same problem on my 92. Its the master window control switch on the driver's side.
Fairly easy to replace once you get the door panel off. About $100 from subaru, but they show up on ebay often. Sometimes on this site.
In the meantime you should be able to get that switch to work by pressing down a bit on the back of that switch while using it normally to close the window.
things went worse...
while I am searching for a master window control switch as recommended. Now in addition to the previous described problem I cannot operate the drivers side window anymore although I do hear the motor running. I really wander wether this also can be blamed on a faulty switch or if this is part of a more sever problem...
Marcus |
That's likely the "Sleeve Lock". It's the little plastic part that attaches the cable to the window assembly. Taking the door panel off will verify this.
