Old 09-09-2019, 03:43 PM
Andrew P.'s Avatar
Andrew P. Andrew P. is offline
The Ebony ones are faster.
AMR coil over issue.
I've had the AMR coil overs installed on my 92' for 4 years.
The car handles completely different and I like it.
However, this last weekend I noticed that the rubber part of the top mounts on the front coil overs are pretty deteriorated. I'm not feeling too safe about driving it again until I figure out how to fix it.
I've contacted Andy at AMR but I haven't heard back yet.
I'll attach the pics that I sent to him.
Any input is appreciated.
92' Ebony. Magnaflow exhaust, tinted windows, STI wheels, 97' grille, Bontrager Works SB, ECUtune transaxle and TCU.
77' IHC Scout SSII
Old 09-10-2019, 03:53 PM
SVX_MY_BABY's Avatar
Re: AMR coil over issue.
That is the top mount for the strut, which on an OEM is a separate part. I'm not a mechanic, but if memory serves me correctly you can replace it pretty easily. However you need a spring compressor to do it after the strut is removed from the car.
Peter
Old 09-11-2019, 03:48 PM
Andrew P.'s Avatar
Thanks for the input.
However the top mount that you see is a custom unit made by AMR not the stock part.
I have as of yet to get a response from AMR about a warranty replacement.
I should have been more direct with my question which is should I park it until I can get the parts to fix it? Or can I still drive it?
77' IHC Scout SSII
Old 09-12-2019, 06:48 AM
As I mentioned earlier, I'm not a mechanic. But, it's my understanding that under normal driving a tear in the rubber of a top mount will not lead to catastrophic failure unless the pressure comes off of the strut. ie the wheel becomes airborne over a bump or similar. It will just get noisier and gradually deteriorate more.
Peter
Old 09-13-2019, 04:49 AM
It's safe to drive. There's no way that rubber should have deteriorated like that already. Keep us informed of AMR's response, if you ever get one.
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V,
Old 09-15-2019, 08:50 AM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
That's not part of the coilover, that's the top strut mount. Just order new ones from subaru and have them installed. They are like $60 i think.
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 09-15-2019, 04:46 PM
Andrew P.'s Avatar
I must admit I'm not holding my breath.
77' IHC Scout SSII
Old 09-15-2019, 04:50 PM
Andrew P.'s Avatar
Yes, it is part of the coil over not the stock top mount. I should know, I did buy them and see them before they were installed.
77' IHC Scout SSII
Old 09-16-2019, 01:38 AM
irox irox is offline
I agree with Andrew, the AMR coil overs completely replace the existing shock. They bolt up to the original mount, but right to the metal, there isn't any reuse of the original shock parts.
I've have a fairly good experience with AMR both times I've bought things (including AMR coil overs) from them. I hope they can give you a good experience too!
Could your request have been accidentally lost (small shop, no dedicate customer service department, etc.)... did you email them a few times? Call them on phone?
If you like I would be happy to email them and ask them to respond.
I've said generally positive things about them based on my personal experience with them, also I may purchase another set of AMR coil overs for my latest project once the current shocks become intolerable... may be that will help...? Also, I really appreciate AMR supporting the SVX, and hope they can maintain at a good standing in our community.
Cheers,
Ian.
Old 09-16-2019, 03:48 PM
Andrew P.'s Avatar
Cheers,
Ian.
Thanks. I'll try to contact them again as well.
77' IHC Scout SSII
