WTB Lock/Unlock mating harness
Hi fellow SVXers,
been wanting to add the following switch next to gear selector, but require the mating connector and short length of the OEM wiring loom (about 3-6 inches). The connector is a 5-way (3-up / 2-down) with clip within the plastic housing. TIA. Let me know by PM cost, postage to me in New Zealand.
Re: WTB Lock/Unlock mating harness
still looking for the mating part....
The wiring loom should be there. I see no point in them removing it for certain vehicles. Unless your car is pre-94?
I have the wiring loom, I don't really want to cut it out of my harness but if you really need it and the right amount we can work a deal. -Sam
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker |
The option was not available here in New Zealand, hence I would like to make it happen. Maybe the same connector is used on other Subaru's of same period also for central locking?.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 10-18-2017 at 02:50 AM. |
