Alignment shop can't get the front right camber back into spec
I need the board's help on this one. After replacing all struts, mounts, rubbers, ball joints, tie rod ends, and the rear camber hardware, I had the local Firestone shop align my vehicle. I did not replace the bushings on the front A arms or the rear trailing arms. They are not able to bring the front right camber back into spec and suggested that I get a "camber kit". I don't think such kits exists for this car besides the OEM camber bolts.
Neither of us could find any signs of damage on the lower A arm or the spindle. The car pulls very slightly to the right but other than that, she drives great. I was tempted to make the camber bolt more eccentric by welding and grinding a bead on there. This sounds rather red neck like and I hope to find a better solution, if it exists. See the attached PDF file for the printout from the alignment computer. Looks like my camber is at -1.7º and the normal range is -1.2º to 0.3º. The car have not been in a wreck on my watch and no signs of any damage under the vehicle or on the body. Thanks for any advice.
If it ain't broken it, doesn't have enough features!!! '92 SVX LSL '03 4Runner '96 FZJ80 Landcruiser '90 Mercedes 300E |
Re: Alignment shop can't get the front right camber back into spec
You can get a camber kit to allow for more camber than the stock bolts, we had them on the racer. I believe we got them from Summit??
Holy cow, no crap? If you can get me a link, that'd be great!
very cool, thanks guys for posting the two links. I see that Ingalls cam bolt from Summit is good for +/- 1 degree. The SPC 81260 from summit is good for +/- 1.75 degrees SWEET.
Anyone have any preference on which one to purchase? I think I'll purchase a camber gauge as well just for S&G! Cheers.
well, I finally got around to installing the SPC 81260 camber bolts on the front. I'm comparing the OEM camber bolt vs the 81260 bolts and I don't see how they're going to correct 1.75 degrees! The SPC bolts have lobes that are smaller in diam than the factory camber bolts. I don't think they will work for the front? I'm not installing the SPCs until I get more info on this. Maybe I'm missing something....
If it ain't broken it, doesn't have enough features!!! '92 SVX LSL '03 4Runner '96 FZJ80 Landcruiser '90 Mercedes 300E Last edited by alia176; 11-05-2011 at 05:28 PM. |
EDIT:
http://svx-motorsport-accessories.st...ncambolki.html Too bad camber bolts can't fix my caster issue :/ Last edited by Lookin4SVX; 08-22-2011 at 09:53 AM. |
