5mt cable trans replaced by hydro push style?
I want to get a new trans. My question is this, since there are very few cable transmissions out there up tp the job, can i convert a push style hydro trans to accept a cable? Is it more than just bolting up the cable and hooking it up the end of the fork? Well please anyone throw some knowledge at me.
Tom |
I don't know for certain if you can convert every one from hydro to cable, but I do know you can convert some years. I personally am using a 98 rs trans in my legacy converted from hydro to cable. You need to change the pivot pin position from the top one to the bottom (or vice versa, I forget right now). And use the cable style clutch fork. I assume you are using a cable style clutch/brake bracket, but if not you need that specific bracket. My question to you though is, why not use the hydro setup?
I do agree with using the hydro setup. In the end you have a better product. Since you've already put so much into your car so far, this should almost be a given.
WRX pedals would probably be the easiest ones to install. It's too bad you weren't closer as you could see how good the pedals fit. See http://svx-iw.com/pics/5speed/images/IM002358.jpg for a pic of the SVX pedals beside the WRX pedals. The only modification was I cut the top 2 bolt holes off the SVX assembly (near the brake switch) and welded it to the end of the WRX assembly.
I may do this this in time, but right now, I am not too concerned with converting over to hydro.
Thnx for the pix dave Tom |
I don't belive there is really any benifit is changing from cable to hydro unless you are gonna use a pull style tranny/clutch. Altho no one seems to be able to conclude this answer; I'm sure Subaru uses the pull style clutch becuse it's desing makes it hold stronger. You should be able to get a clutch that will hold as much as you want with the cable tranny, just as much as a push style hydro tranny. The only real reason to switch to a hydro pedal assembly is if you plan to run a pull style tranny, ( ie. Turbo Legacy, WRX, STI)
