Go Back   The Subaru SVX World Network > SVX Main Forums > Wanted or For Sale > SVX's and SVX Parts Wanted > SVX Cars Wanted
Old 07-14-2020, 04:43 PM
Project svx wanted
Been kicking around ideas for a new project car. So long as the body is decent I'm good with a roller lmk if anyone has one
Old 07-15-2020, 11:58 AM
Re: Project svx wanted
Good to see you're still around......interested in what your Project will be
Old 07-15-2020, 01:05 PM
I think I have a good local guy from Facebook who has a 96 roller I'll probably pick up. Thinking of throwing an ls dry sump in it. Eventually I'll build a a turbo or s/c depending on costs etc for it. I'd like to put roughly 600 to the rear wheels long term goal. Obviously there will be a lot of custom fab work to make it happen but that's what projects are for! Great to hear from you Huck. I see your posts on FB from time to time but I tend to just lurk on the web these days
Old 07-15-2020, 01:12 PM
Yeah, I'm not as active online as I used to be, Family and Life has kept me pretty busy....but still Got my subies.....had 64 of them so far
Old 07-15-2020, 02:48 PM
Talking Re: Project svx wanted
That's borderline madness just fyi
Old 07-16-2020, 04:10 AM
....Pretty sure I crossed that border long ago........
Old 07-16-2020, 10:27 AM
wdb wdb is offline
dances with roads
I like "beyond eccentricity" myself. Makes 'em pause for a sec.
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 08-03-2020, 07:07 PM
ZoraSVX ZoraSVX is offline
Tom, are there many other LS-swapped SVXs out there? Personally, I'm looking for a nice stock one, but can appreciate a properly-done swap. Would love to see some.
Old 12-07-2020, 05:38 PM
I only know of one ever done. Not a whole lot of info available and from what I have heard it was parted out? Who knows.
Currently I have completed the rear subframe from a 350z install and have the rear suspension done so long as I can find a lock collar for my struts. Front suspension is done besides the sway bar but with no front axles I have plenty of room for that. Front x-member is nearly done, just need to refill my argon tanks and get the sway bar figured in. Trans looks like it is in perfect position with everything pushed back as far as I dare it puts the shift linkage exactly where I need it. Will need to make up a trans cross member which should be pretty simple. Once that's done I gotta get a flange adapter for the tran output and get a custom driveshaft made. Then it'll be strictly engine... Intake, fuel system, ems, and cooling. There's also the cage I need to build but I did get a good tubing bender which should make it a little easier. Slow progress is better than no progress
Old 12-08-2020, 08:03 AM
wdb wdb is offline
dances with roads
Indeed it is!
