Old 12-20-2002, 11:22 AM
mattski mattski is offline
Cam and crank seal replacement
I will be replacing seals on my 95 Legacy tomorrow and could use some advice on the process. I do not own a seal puller. Can I get by without one or should I invest in one?
Thanks in advance,
Mattski
97 LSi Ebony Pearl 130k Midlife Crisis
93 Legacy Wagon 180k Training Wheels
98 Outback 180k
98 Dodge Durango 120k Ski Bus
A multitude of skis to feed my need to go faster, faster until the thrill of speed overcomes the fear of death.
Old 12-21-2002, 09:16 AM
red95svx
some advice
Just a quick piece of advice for you. When we change crank seals at our dealership, we also change the lower grommet seal at the same time (part #13594AA011...this is also called the lower timing belt cover seal). It's not expensive, it's easy to put in, and worth your while to do it if your going to do the crank seal.
Old 12-21-2002, 05:22 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
Personally I use an 1/8th inch bit and cordless drill to puncture the seal (BE VERY CAREFUL NOT TO SCRATCH THE SHAFT OR CASE!) and then insert a 90° pick through the hole. Using a pair of side cutter pliers (otherwise known in the trade as 'dykes', probably a mispronounciation of the contraction 'diags' for diagonal cutters. Whew.... ) grab the shank of the pick and pry against the end of the shaft to remove the seal. Use a GOOD quality pick, otherwise excessive prying will leave the end of it inside the seal while the seal remains in the engine. If this happens just start over in another position and make sure you retrieve the broken piece after the seal is finally removed.
Usually this works well, just use some patience and you'll do o.k.
Old 12-24-2002, 09:26 AM
kuoh kuoh is offline
I'm planning to order a bunch of parts to revitalize my SVX and this is one of them. I'm not sure what a 90° pick looks like, but would a small bent nail work? Is that seal usually on pretty tight?
KuoH
Old 12-24-2002, 12:25 PM
Beav's Avatar
Not as old as Randy
http://www.sears.com/sr/product/summ...id=00940749000
Old 12-24-2002, 01:10 PM
Thanks Beav, I used a screwdriver and some gentle prying but will try your method next time.
Happy Holidays,
Mattski
98 Outback 180k
Old 12-24-2002, 09:30 PM
Beav's Avatar
Not as old as Randy
Happy Holidays,
Sometimes you can get away with that but it's not very safe as it's real easy to scratch the shaft. Glad it worked out for you though.
