Noisy, squeeky belt when not warmed up.
10 characters.
Re: Noisy, squeeky belt when not warmed up.
It may just need to be tightened. Does the belt look cracked or shiny and glazed from slipping? If so it should be replaced.
I literally just fixed this exact problem on my car today. My belts were just a little too loose. I read in a some thread here that being able to give them 1/4 of a turn is about the right tension.
In my case, the belts were brand new, and I think they may have just stretched out and broken in a little bit. Anyways, hopefully, the answer will be that simple for you! There is a good how-to in the Alternator section that illustrates where the bolt is you need to tighten. Good luck!
Dan Taney 1996 Subaru SVX LSi (Red) 2019 Subaru WRX LTD |
belt.................
Agreed.... inspect then tighten that belt up. It takes maybe 5 minutes and will be maybe the easiest thing you ever do under the hood of an SVX
10 characters.
10 characters.
I have the same problem, but I seem to be missing that bolt. Does anyone know which part # it is?
1992 LSL Pearlie: 108k, 15min/$15 mod, Alternator wiring "upgrade," Power Mode switch, K&N drop-in, 4500k 35w low-beam HIDs, 3000k 35w fog HIDs, lots more planned (pending funds, of course)- 4.44 5spd being at the top of the list. "We laugh at honour and are shocked to find traitors in our midst." -C.S. Lewis |
