Z32 Maf, injectors, programming, etc..
LAN... I've been wondering something for awhile, and *yes this is off topic... deal with it* (you can PM me the answer if you'd like)
I understand the basics of ECU decoding, however I in no way could do it myself. I've done some research specifically regarding the DSM ecu, and found how time consuming this process can be. I'm not sure if you've looked into products such as "Hondata" and "DSMlink" however I was wondering if this was even in the realm of possible. (laptop adjustable E-prom. basically lets the end user control most aspects of the stock ECU. PM if you have any questions about the tech) I know you probably don't want to put the time into it, as SVXes don't exactly have the most lively aftermarket, but if this was something that could be done with some basic programming and modified hardware, I think we could really get these cars preforming at a level beyond most peoples dreams. This would allow tuning with larger injectors, timing maps, really the possibilities are almost endless. Let me know if this is way out of our league as far as cost effective or even possible. Thanks
Greg 97 Red SVX LSi clean 96 Black SVX LSi beater 90 Red Eclipse GSX track ho 99 Ford F250 work horse My Locker |
It's out of the league of the current market that's for sure. Both in price and in doability. The svx ECU isn't as easy to tune as others out there. It's a better ECU than the others but it has more things that need to be adjusted when fuel injectors need to be changed. Some of these things are particularliy hard to adjust. I make a point of only releasing products that I am confident people will have success with and I'm confident end user tuning for the svx right now would be a dissaster. I think with the stage 2v5 software out now that we've met the needs of pretty much everyone for the time being. There are those who insist on trying other things but if they come around they will find that the stage 2 software is all they need. This doesn't mean end user tuning will never be. Should the community develop to where it's a viable product to release then I will revisit the decision.
The Z32 MAF will read 400HP of air right, so are the stock fuel injectors now the limiting factor?
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles My WRX's Cardomain Page |
-Chike
Tom and I have both run 9 lbs of boost on the factory injectors. 9 lbs is way more than 300 hp.
-Chike P.S. I never realized you're on the stock injectors LAN??? I thought the prototype used the nismos?
"Wise men talk because they have something to say; fools, because they have to say something." - Plato 2013 Cosmic Blue 5spd Evo X GSR 2006 Galaxy Gray 6MT RX-8 (sold) 2006 Steel Gray WRX TR (sold) 1996 Brilliant Red SVX L (sold) Last edited by Chiketkd; 12-08-2005 at 01:58 PM. |
The z32 maf meter will read more like 550hp of air. The fuel injectors are the limiting factor but someone, I think bill or tom has tested them at higher fuel pressures and found that they perform well on up through 60 something psi. This thread is about pistons though....let's not hijack it.
People are finally going to cc the heads of both the ej22 and the svx; that's definitely someting we should keep on track on. It's about time. This year is looking great for the svx; people are actually doing stuff instead of debating it. Quote:
I agree with you 100%. Stuff is actually getting done this year. Keep up the great work Mike! -Chike
I think a 6mt and a 300hp figure is more than enough. We still want to drive a reliable engine (lasting) with an acceptable fuel consumption. For most of us those cars are for daily usage.
We shouldn't forget these factors.
split and moved some posts to keep the piston thread on track and keep this good discussion going.
-Chike
So-
Got my maf from Walter today. Will be ordering the stage 2 tomorrow. intake/exhaust setup: custom butcher exhaust K&N filtercharger (need to clean it) Intake silencer removed Will bumping up the fuel pressure at this point be worth anything on my setup or a waste of time for now.
I don't think you need to adjust the fuel pressure, as the Stage 2v5 chip will richen the afr similar to the stage 1v4 (or is it v5). With your mods and the Z32 MAF, your afr will probably remain nice and rich in the upper rpms. If you ever add a mod such as performance camshafts, then bumping up your fuel pressure will be needed. -Chike
Mychailo :: 2006 Silver Mitsubishi Evolution 9, E85, 34 psi peak, 425wtq/505whp DJ :: 1995 Laguna Blue SVX L AWD 5MT (sold) Visit my locker SVX Mods: ND iridium spark plugs, Impreza RS fpr, afr tuned to 13.2:1 using a custom MAF bypass, custom exhaust, WRX 5MT w/ STi RA 1st-4th gear & stock WRX 5th gear, Exedy 13 lb flywheel & Sport Clutch, STi Group N tranny & engine mounts, urethane spacers in rear subframe, rear diff mounts, and pitch stopper, SVX Sport Strut Springs (185f/150r), custom 19 mm rear swaybar, urethane swaybar mounts, Rota Torque 17x8", 225/45-17 Proxes 4 tires, Axxis Deluxe Plus organic brake pads. Last edited by mbtoloczko; 12-09-2005 at 07:12 PM. |
