5 Speed (pedal box) question
I'm using 2002 2.5RS pedals, same as WRX pedals. From what it looks like, I'd be best off removing the clutch pedal and mounting it to the side of the SVX box. I'd be interested in pics if anyone has pictures of their modded SVX/WRX/Impreza boxes.
Thanks, John |
Is this for a hydraulic setup? If so keep the clutch/brake and just use the SVX gas pedal.
yes...almost
there are the 4 holes that bolt to the brake booster...those are fine. the other 2 holes don't line up. You could easily weld on a plate to the pedal box so that you can bolt up the top 2 holes. Solid pedals are happy pedals.
that's the only place to put it.
Take a look at the pics I took during the conversion: http://svx-iw.com/pics/5speed/ As for the wires, most of them will be pulled inside the car.
