loud squeal from passenger...
Every time I drive my SVX in the snow, my passengers always emit loud squeals. Anyone ever experienced this, and if so, do you know of any good fixes?
Thanks,
I nomally drive pretty fast. Ask Doug. My motto on the road is "if a soccer mom mobile, a semi or a Lada passes you, you should not be driving."
With that said, we have tolls in IL. We have express lanes in the tolls. They are wide enough for one car and speed limits are set to about 30 mph. I have been known to go through them at around 70+ Why? why not? The technology behind them can take your picture up to 130+ (and I personally know the guy who developed that system). I once had a gf that would squeal and leave fingernail marks on my hand because she thought we are going to hit the barrier and die. I kept telling her that she will never die in my car. Period. At lease not while I am driving anyways. L
Re: loud squeal from passenger...
-Steve Member #895(the member formerly known as BurgundyBeast) 01' MSM Lexus IS300 |
Kenn |
I find the squeals less audible if the passenger is stored in the trunk. This also solves the problem of persistent or lingering passengers.
The problem with using alcohol to dampen the squeal is that it increases the risk of leaking from the esophageal seal. Synthetics like valium don't increase leaking, and some synthetics (compazine, thorazine) may actually prevent leaks. |
You are going to slow. Speed up and slide longer with more 360 spins. When the passenger yells that they want to get of the car "NOW", just let them out. Problem sloved
I think you found a good excuse to install a killer sound system.
Kayvon 92' SVX www.sounddomain.com/id/kayvon |
Press the window lock button. Roll down the passenger's window from the driver's side. I've discovered that it's difficult to scream when your teeth are chattering.
keep the bodys in your other car...the smell get bad after awhile
I find having NO pass. are the best but if you need one or wnat one...blindfold em and tell them its a surprise where you are going...when the drive is done...just say "surprise you survived" the SVX was made to be driven....not lumbered around in! |
I find that most annoying noises in the SVX go away after I turn up my stereo
-Johnny (prefers the passenger to make the driver squeel)
Pearl '92 LS-L 179K (Historic 1st 5-speed SVX) Mods: 5-speed, 4.11's, Group-N motor mounts, dual Magnaflows, cone air filter, Kenwood MP-228 CD/Receiver, white-faced gauges, '97 grill, custom window tinting. Ebony Mica '92 LS 80K Oct 2002 - Dec 2004: Victim of theft. She served me well. You can tell the lack of craftsmanship by the wrinkles in the duct tape. |
Re: Re: loud squeal from passenger...
Down to none |
Re: Re: Re: loud squeal from passenger...
-Johnny (fargin' corksucking icehole of a bastage)
